[GRASS-user] Reconnecting vector attribution with Postgres/PostGIS
Moritz Lennert
mlennert at club.worldonline.be
Mon Feb 2 07:29:59 PST 2015
On 02/02/15 14:36, Markus Metz wrote:
> On Mon, Feb 2, 2015 at 1:57 PM, Moritz Lennert
> <mlennert at club.worldonline.be> wrote:
>> On 02/02/15 13:37, Paul Shapley wrote:
>>> Hi Grass 7 users.
>>> I am trying to connect some vector layers with thier respective
>>> attribute tables in postgres/postgis. The tables all connected under
>>> version 6.4.4 but not since upgrading to version 7RC1 (on winxp in this
>>> instance) they do not. It looks like Grass cannot find the database
>>> password but it is present in 'db.login'. Has anyone else had this
>>> happen? Here are the outputs:-
>> Apparently there was a change in the db driver that has the effect of not
>> allowing whitespace between the different connection parameters.
>> GRASS64:
>> db.connect driver=pg database="dbname=nc_grass,host=localhost" db.tables -p
>> => OK
>> db.connect driver=pg database="dbname=nc_grass, host=localhost"
>> db.tables -p
>> => OK
>> trunk (7.1):
>> db.tables -p
>> => OK
>> db.tables -p
>> =>Error
>> I don't know if this was intended. Please file a bug report.
> Not intended. Please try trunk r64396 (update of db/drivers).
Works now. Thanks a lot !
Moritz
