[GRASS-user] trouble with addons - was: dilation & erosion (mathematical morphology)
Paulo van Breugel
p.vanbreugel at gmail.com
Thu Feb 5 07:15:02 PST 2015
you should be able to install the addon from within GRASS using g.extension
or via the menu (settings - addon extensions). If you mean with 'standard
user' an user without administrative privileges, then yes, I think you
should be able to install the addons, they are normally installed in a
hidden folder (.grass7) in the home folder.
On Thu, Feb 5, 2015 at 3:52 PM, Robert Nuske <rnuske at gwdg.de> wrote:
> Hi Paulo,
> thanks for the hint!
> Now I have some trouble to install the addon:
> As a standard user I am not allowed to create a directory under /usr/lib.
> A second try as root failed because HTML2MAN within "Grass.make" tries to
> call
> $(GISBASE)/tools/g.html2man.py. But the python script is called
> g.html2man.
> After linking g.html2man.py to g.html2man the built of the addon fails
> because
> of a missing python module (ImportError: No module named html).
> This was on ubuntu 14.04 with grass70 from the ppa:grass-devel.
> Version 7.0.0+1svn64464~ubuntu14.04.1 installed today.
> Are addons supposed to be installed by standard users?
> thanks
> robert
> as standard user:
> GRASS 7.0.0 (wgs84):~ > g.extension extension=r.grow.shrink
> svnurl=http://svn.osgeo.org/grass/grass-addons/grass7 --verbose
> Fetching <r.grow.shrink> from GRASS-Addons SVN repository (be patient)...
> A r.grow.shrink/DEPRECATED
> A r.grow.shrink/main.c
> A r.grow.shrink/Makefile
> A r.grow.shrink/r.grow.shrink.html
> U r.grow.shrink
> Checked out revision 64471.
> Compiling...
> mkdir -p /tmp/tmpGP17FI/r.grow.shrink/bin
> mkdir -p /tmp/tmpGP17FI/r.grow.shrink/etc
> mkdir -p /tmp/tmpGP17FI/r.grow.shrink/docs/html
> mkdir -p /usr/lib/grass70/docs/man
> mkdir: cannot create directory '/usr/lib/grass70/docs/man': Permission
> denied
> make: *** [/usr/lib/grass70/docs/man] Error 1
> ERROR: Compilation failed, sorry. Please check above error messages.
> as root (sudo -i):
> U r.grow.shrink
> Compiling...
> mkdir -p /tmp/tmpa27tYO/r.grow.shrink/bin
> mkdir -p /tmp/tmpa27tYO/r.grow.shrink/etc
> mkdir -p /tmp/tmpa27tYO/r.grow.shrink/docs/html
> mkdir -p /tmp/tmpa27tYO/r.grow.shrink/docs/man/man1
> test -d OBJ.x86_64-pc-linux-gnu || mkdir -p OBJ.x86_64-pc-linux-gnu
> gcc -Wall -g -O -I/usr/lib/grass70/include -I/usr/lib/grass70/include
> DPACKAGE=\""grassmods"\" -I/usr/lib/grass70/include -
> I/usr/lib/grass70/include -DRELDIR=\"/tmp/tmpa27tYO/r.grow.shrink\" -o
> OBJ.x86_64-pc-linux-gnu/main.o -c main.c
> : && gcc -L/usr/lib/grass70/lib -L/usr/lib/grass70/lib
> -Wl,--export-dynamic -
> Wl,-rpath-link,/usr/lib/grass70/lib -o
> /tmp/tmpa27tYO/r.grow.shrink/bin/r.grow.shrink
> -lgrass_gis.7.0.0svn -lgrass_raster.7.0.0svn -lm
> if [ "/tmp/tmpa27tYO/r.grow.shrink/bin/r.grow.shrink" != "" ] ; then
> GISRC=/tmp/grass7-root-12200/gisrc GISBASE=/usr/lib/grass70
> PATH="/usr/lib/grass70/bin:/usr/lib/grass70/bin:/usr/lib/grass70/scripts:
> $PATH"
> PYTHONPATH="/usr/lib/grass70/etc/python:/usr/lib/grass70/gui/wxpython:
> $PYTHONPATH"
> LD_LIBRARY_PATH="/tmp/tmpa27tYO/r.grow.shrink/bin:/usr/lib/grass70/scripts:/usr/lib/grass70/lib:/usr/lib/grass70/lib:/usr/lib/grass70/lib"
> LC_ALL=C /tmp/tmpa27tYO/r.grow.shrink/bin/r.grow.shrink --html-description
> /dev/null | grep -v '</body>\|</html>' > r.grow.shrink.tmp.html ; fi
> VERSION_NUMBER=7.0.0svn VERSION_DATE=2015 \
> python /usr/lib/grass70/tools/mkhtml.py r.grow.shrink >
> /tmp/tmpa27tYO/r.grow.shrink/docs/html/r.grow.shrink.html
> VERSION_NUMBER=7.0.0svn /usr/lib/grass70/tools/g.html2man.py
> /tmp/tmpa27tYO/r.grow.shrink/docs/man/man1/r.grow.shrink.1
> /bin/sh: 1: /usr/lib/grass70/tools/g.html2man.py: not found
> make: *** [/tmp/tmpa27tYO/r.grow.shrink/docs/man/man1/r.grow.shrink.1]
> Error
> 127
> rm r.grow.shrink.tmp.html
> Am Donnerstag, 5. Februar 2015, 14:53:05 schrieb Paulo van Breugel:
> > Check out the r.growth.shrink addon.
> > On Thu, Feb 5, 2015 at 1:59 PM, Robert Nuske <rnuske at gwdg.de> wrote:
> > > Hi there,
> > > looking at some noisy raster map, I would like to clean up the patches
> > > (map
> > > consists only of one class and NULL) using basic mathematical
> morphology
> > > (dilation & erosion) in GRASS 7.0.
> > > The dilation can easily be achieved with r.grow.
> > > But the erosion seems not to be as straight forward.
> > > Since the example about shrinking was removed from the help page of
> r.grow
> > > in
> > > GRASS 7.0 (http://grass.osgeo.org/grass70/manuals/r.grow.html), I
> hoped
> > > for an
> > > easier way to carry out the erosion. Looking in vain for a raster
> command
> > > named shrink or erode, I tried a negative distance in r.buffer (->
> error)
> > > and
> > > negative radius in r.grow (treated as absolute value).
> > > The following produce identical output with grown patches.
> > > r.grow in=mod_10_33 out=mod_10_33_1 radius=1.1
> > > r.grow in=mod_10_33 out=mod_10_33_2 radius=-1.1
> > > Any suggestions for a quick erosion?
> > > thanks
> > > Robert
> > > _______________________________________________
> > > grass-user mailing list
> > > grass-user at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150205/13a237dc/attachment-0001.html>
