[GRASS-user] GRASS pygrass - composite
Pierric de Laborie
pierric.delaborie at gmail.com
Wed Feb 11 04:55:52 PST 2015
Dear Pietro,
I ran the same command with the highest level of verbose. Unfortunately it
didn't give much more information when blocking at the problematic step.
I also started the same command from GRASS GUI on another debian machine
and it got stuck also. It is like the installation on Debian Wheezy doesn't
fully work (?)
GRASS 7.0.0svn (222):~/Grass_test >* g.gisenv set="DEBUG=5" *
D1/1: G_set_program_name(): g.gisenv
D1/5: G_set_program_name(): g.gisenv
D2/5: G_option_to_separator(): key = separator -> sep = '/'
GRASS 7.0.0svn (222):~/Grass_test > * r.composite red=B5 at PERMANENT
green=B4 at PERMANENT blue=B3 at PERMANENT output=mycompo*
D1/5: G_set_program_name(): r.composite
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/cell/mycompo
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/WIND
D2/5: file open: read (mode = r)
D2/5: G__read_Cell_head
D2/5: G__read_Cell_head_array
D3/5: region item: proj: 1
D3/5: region item: zone: 32
D3/5: region item: north: 3948015
D3/5: region item: south: 0
D3/5: region item: east: 841215
D3/5: region item: west: 0
D3/5: region item: cols: 841215
D3/5: region item: rows: 3948015
D3/5: region item: e-w resol: 1
D3/5: region item: n-s resol: 1
D3/5: region item: top: 1.000000000000000
D3/5: region item: bottom: 0.000000000000000
D3/5: region item: cols3: 1
D3/5: region item: rows3: 1
D3/5: region item: depths: 1
D3/5: region item: e-w resol3: 1
D3/5: region item: n-s resol3: 1
D3/5: region item: t-b resol: 1
D1/5: G_find_raster2(): name=B5 mapset=PERMANENT
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/cell/B5
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/cellhd/B5
D3/5: region item: south: 3716085
D3/5: region item: west: 613785
D3/5: region item: cols: 7581
D3/5: region item: rows: 7731
D3/5: region item: e-w resol: 30
D3/5: region item: n-s resol: 30
D3/5: region item: format: 1
D3/5: region item: compressed: 2
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/fcell/B5
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/g3dcell/B5
D3/5: create window mapping (841215 columns)
D1/5: G_find_raster(): name=MASK mapset=PERMANENT
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/cell/MASK
D1/5: G_find_raster2(): name=B5 at PERMANENT mapset=
D1/5: G_find_raster(): name=B5 at PERMANENT mapset=
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/colr2/PERMANENT/B5
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/colr/B5
D3/5: adding rule 0=0.00 0 0 0 34457=34457.00 255 255 255
D1/5: G_find_raster2(): name=B4 mapset=PERMANENT
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/cell/B4
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/cellhd/B4
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/fcell/B4
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/g3dcell/B4
D1/5: G_find_raster2(): name=B4 at PERMANENT mapset=
D1/5: G_find_raster(): name=B4 at PERMANENT mapset=
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/colr2/PERMANENT/B4
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/colr/B4
D3/5: adding rule 0=0.00 0 0 0 26225=26225.00 255 255 255
D1/5: G_find_raster2(): name=B3 mapset=PERMANENT
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/cell/B3
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/cellhd/B3
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/fcell/B3
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/g3dcell/B3
D1/5: G_find_raster2(): name=B3 at PERMANENT mapset=
D1/5: G_find_raster(): name=B3 at PERMANENT mapset=
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/colr2/PERMANENT/B3
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/colr/B3
D3/5: adding rule 0=0.00 0 0 0 23258=23258.00 255 255 255
D2/5: G_file_name(): path = /tmp/grassdata/222/PERMANENT/GDAL
/tmp/grassdata/222/PERMANENT/.tmp/climvartest/5566.0
/tmp/grassdata/222/PERMANENT/.tmp/climvartest/5566.1
Creating color table for output raster map...
0..6..12..18..25..31..37..43..50..56..62..68..75..81..87..93..100
Writing raster map <mycompo>...
0..
2015-02-11 12:15 GMT+01:00 Pietro <peter.zamb at gmail.com>:
> On Wed, Feb 11, 2015 at 11:51 AM, Pierric de Laborie
> <pierric.delaborie at gmail.com> wrote:
> > Running the same command in GRASS GUI (command shell) on Windows works
> fine
> > and creates a composite in a few seconds. I am starting to think that it
> is
> > due to the way I installed Grass on this Linux machine (I used the
> following
> > link
> http://grasswiki.osgeo.org/wiki/Compile_and_Install#GRASS_7_on_Debian_Wheezy
> you can have more info setting g.gisenv set="DEBUG=1" up to 5 I guess.
> http://grasswiki.osgeo.org/wiki/GRASS_Debugging
> Pietro
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150211/c155f3e5/attachment-0001.html>
