[GRASS-user] Help with defining DB Drivers for input and outputs
Moritz Lennert
mlennert at club.worldonline.be
Wed Feb 11 15:42:58 PST 2015
On 12/02/15 00:12, Mark Wynter wrote:
> Within the same mapset, is it possible to specify SQLITE as the database
> for the output layer, whilst using a map as an input that has a PG driver?
> I’ve read the manual and tried a few approaches, but I found the outputs
> still get written to PG. May be I’ve missed a critical step? See
> messages below. I also experimented with v.add.table and v.add.columns
> to the empty map, to no avail.
You should use db.connect to set your default settings to SQLite, then
run your command. By overwriting your map in the v.net.allpairs call you
overwrite everything, including any db connections set before and you
use the default mapset connection settings which seem to be set to PG.
Moritz
> I want the outputs written to sqlite, because v.out.ogr and
> v.out.postgis when the attributes are stored in PostgreSQL seems
> unworkably slow (which may be a pg_conf issue but my DB is performing
> well at scale for non-GRASS parallelised workflows)?
> I want to keep the input attributes still in PostgreSQL because its the
> road table, and the fwdcost and bwdcost columns get updated by data from
> non-GRASS schema.
> I need the fastest pipeline performance possible for when I scale the
> solution out (which will be done using GNU Parallel).
> Right now I’m stuck between a rock and a hard place.
> Really hoping someone can help me out… :-)
> Thanks
> Mark
> #CREATE EMPTY MAP TO HOLD THE OUTPUTS
> g.remove -f type=vector pattern="temp**"
> layername="temp_8
> v.edit --overwrite tool=create map=$layername
> v.db.connect map=$layername table=$layername driver=sqlite
> database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db’
> v.info $layername
> #RUN THE ANALYSIS, WHERE THE INPUT LAYER ATTRIBUTES RESIDE IN POSTGRESQL
> v.net.allpairs --overwrite in=nsw_road_network_final_connected
> cats=1-100out=$layername afcolumn=fwdcost abcolumn=bwdcost
> # NO GOOD - THE OUTPUT ATTRIBUTE TABLE STILL APPEARS IN PGL
> GRASS 7.0.0svn (nodeclean):~ > v.edit --overwrite tool=create map=$layername
> Building topology for vector map <temp_8 at PERMANENT>...
> Registering primitives...
> 0 primitives registered
> 0 vertices registered
> Building areas...
> 0 areas built
> 0 isles built
> Attaching islands...
> Attaching centroids...
> Number of nodes: 0
> Number of primitives: 0
> Number of points: 0
> Number of lines: 0
> Number of boundaries: 0
> Number of centroids: 0
> Number of areas: 0
> Number of isles: 0
> v.edit complete.
> GRASS 7.0.0svn (nodeclean):~ > v.db.connect map=$layername
> database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
> WARNING: Table <temp_8> does not exist in database
> <$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db>
> The table <temp_8> is now part of vector map <temp_8> and may be deleted or
> overwritten by GRASS modules
> DBMI-SQLite driver error:
> Unable to create index:
> create unique index if not exists temp_8_cat on temp_8 ( cat )
> no such table: main.temp_8
> WARNING: Cannot create index
> Select privileges were granted on the table
> GRASS 7.0.0svn (nodeclean):~ > v.db.connect -p map=$layername
> Vector map <temp_8> is connected by:
> layer <1/temp_8> table <temp_8> in database
> </var/tmp/nodeclean/PERMANENT/sqlite/sqlite.db> through driver <sqlite>
> with key <cat>
> GRASS 7.0.0svn (nodeclean):~ > v.info $layername
> | Mapset: PERMANENT
> | Location: nodeclean
> | Database: /var/tmp
> | Title:
> | Map scale: 1:1
> | Name of creator: root
> | Organization:
> | Source date: Wed Feb 11 22:49:13 2015
> | Timestamp (first layer): none
> | Map format: native
> | Type of map: vector (level: 2)
> | Number of points: 0 Number of centroids: 0
> | Number of lines: 0 Number of boundaries: 0
> | Number of areas: 0 Number of islands: 0
> | Map is 3D: No
> | Number of dblinks: 1
> | Projection: Albers Equal Area
> | N: 0 S: 0
> | E: 0 W: 0
> | Digitization threshold: 0
> | Comment:
> GRASS 7.0.0svn (nodeclean):~ > v.net.allpairs --overwrite
> in=nsw_road_network_final_connected cats=1-100 out=$layername
> WARNING: Vector map <temp_8> already exists and will be overwritten
> WARNING: Table <temp_8> linked to vector map <temp_8> does not exist
> Building graph…
> #### Outputs of temp_8 visible in PostgreSQL….#########
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
