[GRASS-user] SQLite Error
Mark Wynter
mark at dimensionaledge.com
Thu Feb 12 02:16:14 PST 2015
Hi Moritz - the SQLite DB seems to be inheriting the schema from the previous PG driver? Even if I db.dropdb…. I don’t encounter this if I create a new location… e.g. test
GRASS 7.0.0svn (nodeclean):~ > db.dropdb database='/var/tmp/nodeclean/PERMANENT/sqlite/sqlite.db'
GRASS 7.0.0svn (nodeclean):~ > db.connect driver=sqlite database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
GRASS 7.0.0svn (nodeclean):~ > db.connect -p
driver: sqlite
database: /var/tmp/nodeclean/PERMANENT/sqlite/sqlite.db
schema: grass
group:
grass70 -text -c EPSG:3577 /var/tmp/test
GRASS 7.0.0svn (test):~ > db.connect -p
driver: sqlite
database: /var/tmp/test/PERMANENT/sqlite/sqlite.db
schema:
group:
On 12 Feb 2015, at 7:05 pm, Moritz Lennert <mlennert at club.worldonline.be> wrote:
On 12/02/15 02:14, Mark Wynter wrote:
> #(2) RESET THE DATABASE DRIVER FOR THE CURRENT MAPSET TO SQLITE
> database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db' schema=grass
> db.connect -p
> #Output
> driver: sqlite
> schema: grass
> group:
> #(5) Run v.net.allpairs….
> g.remove -f type=vector pattern="temp**"
> v.net.allpairs --overwrite in=nsw_road_network_final_connected_copy
> cats=1-10 out=temp_8 afcolumn=fwdcost abcolumn=bwdcost
> DBMI-SQLite driver error:
> Error in sqlite3_prepare():
> unknown database grass
I don't think SQLite supports schemas.
Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150212/c3f22d96/attachment.html>
