[GRASS-user] SQLite Error
Moritz Lennert
mlennert at club.worldonline.be
Thu Feb 12 07:24:33 PST 2015
On 12/02/15 13:30, Mark Wynter wrote:
> Haven’t come across anything to that effect
>> Can you set schema='' or something like that ?
>> Moritz
> I’ve reverted back to using solely PG driver - notwithstanding this
> SQLite issue.
> As a prologue to the several issues I encountered with Grass over the
> last few days…
> The slow rate of writing out the v.net.allpair results from
> PostgreSQL was due to the sheer volume of line strings, as the number
> of pairs increased (n^2). Simple math said stop. I’ve since
> changed my approach and am using v.net.distance in a novel way where
> the to_cat is the origin, and the from_cat is a string of
> destinations - this is an equivalent way of generating multiple
> v.net.paths in a single operation. Moreover, I’m feeding each origin
> - destination collection into GNU Parallel as a separate job, so it
> rips through the data at scale!
It would be great if you could put this info in a more structured form
onto the GRASS wiki, possibly as a FAQ.
Moritz
