[GRASS-user] v.parallel output with self intersecting line
Roy
royroge at outlook.com
Thu Feb 12 10:08:47 PST 2015
Il 12/02/2015 12.59, Moritz Lennert ha scritto:
> On 12/02/15 09:55, Roy wrote:
>> Hi,
>> i'm using v.parallel and i get self intersecting lines (on one side) as
>> result,
>> i obtain this expecially with "hook shaped lines";
> Is it the same as what is reported in this bug:
> trac.osgeo.org/grass/ticket/2531
yes, found it after sending this mail ... it's an already well known
issue, thanks
>> also the resulting vector does not have any associated
>> attribute table, is this behaviour to be expected ?
> AFAIK, yes.
> Moritz
ok then,
thanks, Roy.
