[GRASS-user] Question about r.watershed and flow accumulation grid
Thomas Adams
tea3rd at gmail.com
Fri Feb 13 10:48:26 PST 2015
Stefan,
A fair question; since I know the stream topology from personal experience
it is clear that there should be no break in the stream network and the
flow accumulation grid should reflect that. I am seeing the flow
accumulation values break at a point where they should continue to
accumulate downstream.
Tom
On Fri, Feb 13, 2015 at 11:43 AM, Stefan Lüdtke <sluedtke at gfz-potsdam.de>
wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi Tom,
> just out of curiosity, what do you mean by "break in the flow
> accumulation"?
> Cheers,
> Stefan
> On 02/13/2015 07:12 PM, Thomas Adams wrote:
> > Hello all!
> > I'm making use of the flow accumulation grid in GRASS 6.4.5
> > generated from r.watershed using the SFD (D8) flow algorithm. The
> > DEM has a 250m spatial resolution. What I'm getting is a break in
> > the flow accumulation in a few locations which is causing me
> > serious problems with subsequent processing (with help from some
> > here, I have put together some scripting to generate a pixel
> > connectivity file for a distributed hydrologic model).
> > Besides going to a higher resolution DEM, are there any thoughts as
> > to how I can eliminate these flow accumulation breaks?
> > Thank you, Tom
> > _______________________________________________ grass-user mailing
> > list grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> Stefan Lüdtke
> Section 5.4- Hydrology
> Tel.: +49 331 288 2821
> Fax: +49 331 288 1570
> Email: sluedtke at gfz-potsdam.de
> Helmholtz-Zentrum Potsdam
> Deutsches GeoForschungsZentrum GFZ
> (GFZ German Research Centre for Geoscience)
> Stiftung des öff. Rechts Land Brandenburg
> Telegrafenberg, 14473 Potsdam
> PGP Public Key: http://bit.ly/13d9Sca
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.11 (GNU/Linux)
> iQEcBAEBAgAGBQJU3kXYAAoJEB5GAbKcg+D8YqMH/jgJZ70cz69IJal6ICi66wqW
> lQYnnko592KAOlFDu1lReZhWWVgeA59rDsYA2Gg/rBzoL9Nst3hzIJDWqnhIWl3W
> YgF/vOJgTRnrNJtOibGpOc8hxrHwElxU7afYlXU8Zk+4tXdZRK4/vrQ4tKEcbY0z
> MrhAYjR66RRpoNf9/3WJ3s14CpPA+KEkOaysOOoTV6Ni7qZTK8rVxt+svQQoPtW+
> 5QwRJLkLeM6bUrqfQifHis91j4k3JSoSp7ZjIInKwi1tvCSfcFQhzvANs4x8e1Lo
> Q5wDbzHshhJieGKyraUZyT8cn9vszv9cm2Sf49O/0FWVz3Eyc9vsKFxVcvfEb1E=
> =Sy/3
> -----END PGP SIGNATURE-----
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150213/0d1c9d82/attachment.html>
