[GRASS-user] v.extract where clause with puthon script
Roy
royroge at outlook.com
Sat Feb 14 07:00:43 PST 2015
Dear all,
i'm trying to extract some vectors using attribute names using python
script: (grass 6.4.4)
i have a column with "des" values : river, canal
and i have to extract only the features of type 'canal'
then of type 'river' and so on...
import grass.script as grass
env = grass.gisenv()
grass.run_command('v.extract', input='idro', output='canal_idro',
where='des = canal', overwrite='True')
maybe i'm missing the correct sintiax of the "where" clause because i
only get
a buffer overflow as result,
thanks for any help,
Roy.
