[GRASS-user] v.in.ogr with new location doesn't import my data
G. Allegri giohappy at gmail.com
Wed Feb 18 04:07:14 PST 2015
I forgot to say that I'm using grass 7 on a Ubuntu machine
2015-02-18 13:06 GMT+01:00 G. Allegri <giohappy at gmail.com>:
> I'm using v.in.ogr with the location option. The new location is created
> correctly, and the projection is set to the one defined by my shapefile's
> .prj file, but no data is imported. The mapset is empty.
> The command line reports the following message:
> WARNING: All available OGR layers will be imported into vector map
>             <centroidi_province>
> Location <workLocation> created
> The same command launched in a preexisting location (and without the
> location option) works fine and the data is correctly imported.
> giovanni
> Giovanni Allegri
> http://about.me/giovanniallegri
> Twitter: https://twitter.com/_giohappy_
> blog: http://blog.spaziogis.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150218/c0204bfb/attachment.html>
