[GRASS-user] v.in.ogr with new location doesn't import my data
G. Allegri
giohappy at gmail.com
Wed Feb 18 06:35:34 PST 2015
Thanks Anna,
yuor example gave me the hint: I didn't set the output parameter, which I
thought could be obtained from the input dataset name.
giovanni
2015-02-18 15:28 GMT+01:00 Anna Petrášová <kratochanna at gmail.com>:
> On Wed, Feb 18, 2015 at 7:07 AM, G. Allegri <giohappy at gmail.com> wrote:
>> I forgot to say that I'm using grass 7 on a Ubuntu machine
>> 2015-02-18 13:06 GMT+01:00 G. Allegri <giohappy at gmail.com>:
>>> I'm using v.in.ogr with the location option. The new location is created
>>> correctly, and the projection is set to the one defined by my shapefile's
>>> .prj file, but no data is imported. The mapset is empty.
>>> The command line reports the following message:
>>> WARNING: All available OGR layers will be imported into vector map
>>> <centroidi_province>
>>> Location <workLocation> created
>>> The same command launched in a preexisting location (and without the
>>> location option) works fine and the data is correctly imported.
> Hm, it is working for me in G70 and G71 (Ubuntu as well):
> v.in.ogr
> input=/home/anna/grassdata/data/shoreline_oceanfront_1998/Shoreline_Oceanfront_1998.shp
> output=test location=testLoc
> Location <testLoc> created
> Check if OGR layer <Shoreline_Oceanfront_1998> contains polygons...
> 100%
> Importing 21 features (OGR layer <Shoreline_Oceanfront_1998>)...
> 100%
> Building topology for vector map <test at PERMANENT>...
> Registering primitives...
> 67 primitives registered
> 19183 vertices registered
> Building areas...
> 100%
> 0 areas built
> 0 isles built
> Attaching islands...
> Attaching centroids...
> 100%
> Number of nodes: 128
> Number of primitives: 67
> Number of points: 0
> Number of lines: 67
> Number of boundaries: 0
> Number of centroids: 0
> Number of areas: 0
> Number of isles: 0
> Anna
>>> giovanni
>>> Giovanni Allegri
>>> http://about.me/giovanniallegri
>>> Twitter: https://twitter.com/_giohappy_
>>> blog: http://blog.spaziogis.it
>>> GEO+ geomatica in Italia http://bit.ly/GEOplus
>> Giovanni Allegri
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Giovanni Allegri
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150218/52fccd3c/attachment.html>
