[GRASS-user] Is the location's VAR file required?
G. Allegri
giohappy at gmail.com
Wed Feb 18 10:26:24 PST 2015
Hi Markus,
I wrote the details in another recent email and I forgot to write the here,
sorry.
GRASS 7.0.0 RC1 on Ubuntu 14.04.
I'm creating a temporary database with an empty start location, with no CRS
defined (proj code 0, i.e. XY).
My location contains only the the WIND and DEFAULT_WIND files with the
following content:
proj: 0
zone: 0
north: 1
south: 0
east: 1
west: 0
cols: 1
rows: 1
e-w resol: 1
n-s resol: 1
top: 1
bottom: 0
cols3: 1
rows3: 1
depths: 1
e-w resol3: 1
n-s resol3: 1
t-b resol: 1
The env variables I'm using are:
export PYTHONPATH='/usr/lib/grass70/etc/python'
export GISRC='/tmp/tmp9YVf_N/gisrc'
export GRASS_VERSION='7.0.0'
export
PATH='/usr/lib/grass70/bin:/usr/lib/grass70/scripts:/home/giova/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin'
export GIS_LOCK=$$
export LD_LIBRARY_PATH='/usr/lib/grass70/lib'
export GISBASE='/usr/lib/grass70'
Whatevere shapefile I try to import I obtain a segfault.
This is the test command:
:/ v.in.ogr dsn="/mnt/data/centroids.shp" output=centroids
location=workLocation -ie
If I add the VAR file with:
DB_DRIVER: sqlite
DB_DATABASE: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
eveythign works fine.
giovanni
2015-02-18 18:08 GMT+01:00 Markus Neteler <neteler at osgeo.org>:
> On Wed, Feb 18, 2015 at 3:24 PM, G. Allegri <giohappy at gmail.com> wrote:
> > I'm getting segmentation faults in case I run a command on a location
> > missing the VAR file.
> On which OS, which GRASS version?
> > I thought it was optional, as it's said here:
> http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly#GRASS_databases
> Please post a reproducible example, thanks.
> Markus
Giovanni Allegri
http://about.me/giovanniallegri
Twitter: https://twitter.com/_giohappy_
blog: http://blog.spaziogis.it
GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150218/3a1311b6/attachment.html>
