[GRASS-user] exit from grass after setting GRASS env variable
Moritz Lennert mlennert at club.worldonline.be
Thu Feb 19 09:24:14 PST 2015
On 19/02/15 18:19, Giuseppe Amatulli wrote:
> Hi,
> i have a very simple question but i'm not able find the simple answer.
> I'm following the procedure for Setting the GRASS environmental
> variables, <http://grasswiki.osgeo.org/wiki/GRASS_and_Shell>in the bash
> environment.
> Everything works grate and I'm able to access to all grass commands.
> My question is how I can exit from grass and return to the
> bash-with-nograss.
You cannot "exit" GRASS as it is not an application by itself. If you do
not want to have access to the GRASS modules anymore, just unset your
environment variables.
If you want to change your prompt, set PS1 to something else.
Moritz
