[GRASS-user] Searching for technical details on how v.rast.stats calculates means and other statistics
RichardCooper
richtcooper at hotmail.com
Fri Feb 20 03:33:17 PST 2015
I seem to be getting an error with r.univar when using a zone file.
I run, g.region as follows:
g.region -a raster=cahpa_i0apr_05216_nc_remapped_nc_1 at prcp05216ijk res=0.22
Then r.univar (see below).
There are 6 categories in the zone file, but r.univar reports null cells for
category 1? Initially I thought it was me not setting g.region correctly,
but I can't seem to get it to work as expected.
Any ideas would be welcome.
Cheers,
Richard
r.univar map=cahpa_i0apr_05216_nc_remapped_nc_1 at prcp05216ijk
zones=BMR_bndry_epsg4326_rasterized at prcp05216ijk
zone 1 Category 1
total null and non-null cells: 4
total null cells: 0
Of the non-null cells:
n: 4
minimum: 3.5821e-05
maximum: 7.74327e-05
range: 4.16117e-05
mean: 5.6472e-05
mean of absolute values: 5.6472e-05
standard deviation: 1.53325e-05
variance: 2.35085e-10
variation coefficient: 27.1506 %
sum: 0.000225888012209907
zone 2 Category 2
total null and non-null cells: 2
total null cells: 0
n: 2
minimum: 3.53024e-05
maximum: 6.23036e-05
range: 2.70012e-05
mean: 4.8803e-05
mean of absolute values: 4.8803e-05
standard deviation: 1.35006e-05
variance: 1.82266e-10
variation coefficient: 27.6635 %
sum: 9.76059491222259e-05
zone 3 Category 3
total null and non-null cells: 1
total null cells: 0
n: 1
minimum: 8.14342e-05
maximum: 8.14342e-05
range: 0
mean: 8.14342e-05
mean of absolute values: 8.14342e-05
standard deviation: 0
variance: 0
variation coefficient: 0 %
sum: 8.14341983641498e-05
zone 4 Category 4
total null and non-null cells: 3
total null cells: 0
This is my zones file:
Type of Map: raster Number of Categories: 6
| Data Type: CELL
| Rows: 231
| Columns: 231
| Total Cells: 53361
| Projection: Latitude-Longitude
| N: 35:38:24N S: 15:10:48S Res: 0:13:12
| E: 140:34:48E W: 89:45:36E Res: 0:13:12
| Range of data: min = 1 max = 6
| Data Source:
| Vector Map: BMR_bndry_epsg4326 at prcp05216ijk
| Original scale from vector map: 1:1
| Data Description:
| generated by v.to.rast
| Comments:
| v.to.rast input="BMR_bndry_epsg4326 at prcp05216ijk" layer="1" type="ar\
| ea" output="BMR_bndry_epsg4326_rasterized" use="cat" value=1 memory=\
| 300
This is the raster file:
Type of Map: raster Number of Categories: 0
| Data Type: FCELL
| Rows: 230
| Columns: 230
| Total Cells: 52900
| N: 35:29:24N S: 15:06:36S Res: 0:13:12
| E: 140:29:24E W: 89:53:24E Res: 0:13:12
| Range of data: min = 0 max = 0.002821672
View this message in context: http://osgeo-org.1560.x6.nabble.com/Searching-for-technical-details-on-how-v-rast-stats-calculates-means-and-other-statistics-tp5188809p5188865.html
Sent from the Grass - Users mailing list archive at Nabble.com.
