[GRASS-user] 7.0.0 Mac OS X Install Notes
William Kyngesburye woklist at kyngchaos.com
Sun Feb 22 19:58:46 PST 2015
Sorry, I just responded to the list email, I was curious about GSL when I looked at your page.
GDAL Complete and Freetype is needed for PIL and cairo.
On Feb 22, 2015, at 9:50 PM, Michael Barton <michael.barton at asu.edu> wrote:
> William,
> I don't know why Jeshua wrote to you since I maintain the wikidot site. I think that GSL is there simply because I went to your frameworks site and pulled in all frameworks you had on the main page. But you're right. I don't use it in my configure AFAICT. I suppose I should remove it it if doesn't do anything.
> As for the other issues, I'll respond
> 1. There IS a link to the Kyngchaos frameworks page in the menu on the right side that shows up on every page. On that frameworks page, it is clearly stated that PROJ and UnixImageIO are a part of the GDAL Complete package
> 2. AFAIK, the order of installing the main frameworks packages makes no difference. The ones for which order matters are included in GDAL Complete. If I am wrong here, please let me know and I will put a note on the site.
> 3. No one has ever reported this permissions issue so far. I don't know what is causing it in this case (unless it is new for 7.0 stable).  AFAIK, the only permissions issue is the need to have a writeable director called "bin" inside the GRASS folder if you are installing extensions. This is a weird quirk of the extensions build system on the Mac. If there is a new permissions issue for 7.0 stable, it needs to be reported. But I have built it in exactly the same way as I've built all other builds recently.
> Cheers
> Michael
> ____________________
> C. Michael Barton
> Director, Center for Social Dynamics & Complexity
> Professor of Anthropology, School of Human Evolution & Social Change
> Head, Graduate Faculty in Complex Adaptive Systems Science
> Arizona State University
> voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
> fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
> www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
>> On Feb 22, 2015, at 5:17 PM, William Kyngesburye <woklist at kyngchaos.com> wrote:
>> PROJ and UnixImageIO are a part of the GDAL Complete package.  Once that is installed (it is the first listed, though order is not specified), the others can be any order.
>> I don't know why GSL is there, that's something I did for QGIS.  Michael?
>> On Feb 22, 2015, at 4:25 PM, Jeshua Lacock <jeshua at 3dTopo.com> wrote:
>>> Greetings,
>>> I noticed the following minor issues while installing GRASS 7.0.0 on Mac OS X. While they are not any obstacles for me, it may block some others from a smooth installation. Therefore I would recommend adding a the following notes to the install page (http://grassmac.wikidot.com/frameworks).
>>> 1. The install page does not link to the PROJ or UnixImageIO Frameworks:
>>> 	http://www.kyngchaos.com/files/software/frameworks/PROJ_Framework-4.8.0-1.dmg
>>> 	http://www.kyngchaos.com/files/software/frameworks/UnixImageIO_Framework-1.5.0.dmg
>>> 2. The order of the install packages for some of the packages is important. It may be nice to list the order in which to install the frameworks (perhaps order the list?)
>>> 3. Following successful installation of the GRASS-7.0.pkg the installed directory permissions are set that a user cannot open the folder until changing the permissions from:
>>> 	drwx------   3 503     wheel    102 Feb 22 14:09 GRASS
>>> This can be resolved by adding “sudo chmod -R 755 /Applications/GRASS” (or similar) the the package installer postflight script.
>>> Thank you so much for all the development over the decades GRASS GIS Team!
>>> Cheers,
>>> Jeshua Lacock
>>> Founder/Engineer
>>> 3DTOPO Incorporated
>>> <http://3DTOPO.com>
>>> Phone: 208.462.4171
>>> grass-user mailing list
>>> grass-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> "Those people who most want to rule people are, ipso-facto, those least suited to do it."
>> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
"Time is an illusion - lunchtime doubly so."
- Ford Prefect
