[GRASS-user] Importing xyz raster with corner coordinates?
Lauri Myllyvirta
lauri.myllyvirta at greenpeace.org
Mon Feb 23 06:17:32 PST 2015
Perfect, thank you!
On Mon, Feb 23, 2015 at 3:15 PM, Moritz Lennert <
mlennert at club.worldonline.be> wrote:
> On 23/02/15 14:48, Lauri Myllyvirta wrote:
>> Hello,
>> I need to import a set of raster data in ASCII xyz format, with the
>> coordinates referring to the southwest corner of the grid cell rather
>> than the center as is the convention. I can think of a number of clumsy
>> ways to solve the problem by scripting, either involving importing the
>> raster first with an incorrect region definition, or by batch editing
>> the text files, but am wondering if there is an elegant way to do this.
>> For example, adding a simple +(resolution / 2) offset to both the lat
>> and lon coordinates would do. I already tested and simply using the
>> correct region definition and hoping that the data falls into the
>> correct grid cells does not work.
> How about r.region (not g.region) with something like:
> r.region YourMap n=n+[res*0.5] etc
> Moritz
Lauri Myllyvirta (Mr.)
senior global campaigner, coal
Greenpeace
mobile +48 66 40 66 382 (Poland, primary)
mobile +86 157 1002 1563 (China)
skype laurimyllyvirta
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150223/31c3af53/attachment.html>
