[GRASS-user] v.generalize: does it take forever?
Fábio Dias fabio.dias at gmail.com
Tue Jan 6 09:48:31 PST 2015
Original:
GRASS 7.1.svn (brasil):~ > v.info map=tc10
 | Mapset:          terraclass                                                |
 | Location:        brasil                                                    |
 | Database:        /home/externo/fabioasd/grass                              |
 | Title:        |
 | Map scale:       1:1                                                       |
 | Name of creator: fabioasd                                                  |
 | Organization:                                                              |
 | Source date:     Sat Jan  3 23:38:40 2015                                  |
 | Timestamp (first layer): none                                              |
 | Map format:      native                                                    |
 |   Type of map: vector (level: 2)                                           |
 |   Number of points:       0               Number of centroids:  5323741    |
 |   Number of lines:        0               Number of boundaries: 12889264   |
 |   Number of areas:        5573197         Number of islands:    1332382    |
 |   Map is 3D:              No                                               |
 |   Number of dblinks:      1                                                |
 |   Projection: Latitude-Longitude                                           |
 |               N:   5:16:18.443667N    S:  18:02:29.687783S                 |
 |               E:  43:59:58.760386W    W:  73:59:29.009623W                 |
 |   Digitization threshold: 0                                                |
 |   Comment:        |
After dissolve:
 | Location:        brasil                                                    |
 | Title:        |
 | Map scale:       1:1                                                       |
 | Organization:                                                              |
 |   Number of points:       0               Number of centroids:  5120039    |
 |   Number of lines:        0               Number of boundaries: 12641473   |
 |   Number of areas:        5369494         Number of islands:    1366321    |
 |   Map is 3D:              No                                               |
 |   Comment:        |
Fábio Augusto Salve Dias
http://sites.google.com/site/fabiodias/
On Mon, Jan 5, 2015 at 5:49 PM, Fábio Dias <fabio.dias at gmail.com> wrote:
> Just for further reference, the v.dissolve takes around 24h in this
> dataset. I'll post the v.info of both as soon as it is finished.
> Any other ideas? I have a fairly powerful server at my disposal, but
> I'm out of ideas...
> On Sun, Jan 4, 2015 at 7:45 PM, Fábio Dias <fabio.dias at gmail.com> wrote:
>> As promised, profile of v.generalize, as of r63952.
>> (The data might not be exactly the same, I might have run v.clean somewhere).
>> I still have the raw profiles, if anyone wants them.
>> F
>> On Sun, Jan 4, 2015 at 6:01 PM, Fábio Dias <fabio.dias at gmail.com> wrote:
>>> Attached is pdf generated with google-perf of v.generalize, using
>>> g7b4. I'm running it again for trunk.
>>> On Sun, Jan 4, 2015 at 5:54 PM, Markus Metz
>>> <markus.metz.giswork at gmail.com> wrote:
>>>> On Wed, Dec 31, 2014 at 5:20 PM, Fábio Dias <fabio.dias at gmail.com> wrote:
>>>>> I fussed about the v.generalize code, thinking about pthread
>>>>> parallelization. The geometry part of the code is *really* fast and
>>>>> can be easily parallelized so it can run even faster. But, according
>>>>> to the profile google-perf gave me, the real bottleneck is inside the
>>>>> check_topo function (which uses static vars and inserts a new line
>>>>> into the vector, not only checks if it breaks topo - got stuck a while
>>>>> in there due to the misnomer). More specifically in the Rtree function
>>>>> used to check if one line intersects other lines.
>>>> The function used in check_topo is Vect_line_intersection() which does
>>>> much more than just testing for intersections. The process could be
>>>> made much faster if Vect_line_check_intersection() would be modified
>>>> such that connections by end points are ignored. But I don't know if
>>>> this would break other modules or other functionality.
>>>> Markus M
