[GRASS-user] g.extension gives an error when installing r.prominence
Markus Neteler
neteler at osgeo.org
Tue Jan 6 14:47:57 PST 2015
On Tue, Jan 6, 2015 at 7:35 PM, Thayer Young <thayeray at yahoo.com> wrote:
> When I try to install the r.prominence extension I get the following error:
> g.extension.py -i extension=r.prominence
> svnurl=http://svn.osgeo.org/grass/grass-addons/grass6
> WARNING: GRASS_ADDON_PATH has more items, using first defined -
> '/Users/thayer/Library/GRASS/6.4/Modules/bin'
> ld: library not found for -lintl
> clang: error: linker command failed with exit code 1 (use -v
> to see invocation)
> ERROR: Compilation failed, sorry. Please check above error messages.
This is strange, for Windows g.extension should download a precompiled
"r.prominence.exe".
Which GRASS GIS 6.4.x version do you use precisely? And on which
Windows Version?
Markus
