[GRASS-user] g.extension gives an error when installing r.prominence
Michael Barton Michael.Barton at asu.edu
Thu Jan 8 09:17:46 PST 2015
William Kyngesburye might have a better idea about why compilation failed.
I do remember having compiling problems a year and a half ago for certain things. But that was on GRASS 7. You might try installing the OSX command line tools from the Apple Developer site.
The error seems to be related to internationalization (ld: library not found for -lintl). This is in gettext. I normally compile with gettext included. I posted a new binary 30 December and then revised it a couple times. When did you download this?
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Head, Graduate Faculty in Complex Adaptive Systems Science
Arizona State University
voice:  480-965-6262 (SHESC), 480-965-8130/727-9746 (CSDC)
fax: 480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
> On Jan 7, 2015, at 3:39 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Tue, Jan 6, 2015 at 7:35 PM, Thayer Young <thayeray at yahoo.com> wrote:
>> When I try to install the r.prominence extension I get the following error:
>> g.extension.py -i extension=r.prominence
>> svnurl=http://svn.osgeo.org/grass/grass-addons/grass6
>> WARNING: GRASS_ADDON_PATH has more items, using first defined -
>> '/Users/thayer/Library/GRASS/6.4/Modules/bin'
>> clang: error: linker command failed with exit code 1 (use -v
>> to see invocation)
>> ERROR: Compilation failed, sorry. Please check above error messages.
> On Wed, Jan 7, 2015 at 10:37 PM, Thayer Young <thayeray at yahoo.com> wrote:
>> I am on Mac OS 10.10.  From the About GRASS GIS window:
>> GRASS GIS 6.4.5svn, SVN Revision 61583M, GIS Library Revision 50937
>> (2012-02-25), Python: 2.7.6, wxPython: 2.8.12.1
>> I installed it using the Michael Barton snapshot , but I installed it using
>> the Kyng Chaos frameworks (I tried both GUIs and went with the Barton
>> version).
> I see. So I add Michael in CC, perhaps he remembers the solution since
> a similar issue was discussed last year:
> http://lists.osgeo.org/pipermail/grass-dev/2014-April/068136.html
> (and related messages).
> Markus
