[GRASS-user] v.generalize: does it take forever?
Fábio Dias
fabio.dias at gmail.com
Thu Jan 8 09:29:14 PST 2015
Another info update (and shameless bump)
Around 18M primitives and 130M vertices.
And I'm left wondering... Has nobody tried to generalize this amount
of data yet? Or I'm going about this on the wrong way?
I even mounted the grassdata dir as a ramdisk to try to speed up the
process, but it is still way too slow...
Thanks for everything,
F
Fábio Augusto Salve Dias
http://sites.google.com/site/fabiodias/
On Wed, Jan 7, 2015 at 2:12 PM, Fábio Dias <fabio.dias at gmail.com> wrote:
> Another interesting update....
> I believed that doing a dissolve before generalizing would speed up
> the process, because it would remove a lot of edges. The data is very
> segmented, stitching would be the right term, I suppose.
> Turns out, that belief is really wrong. The really expensive part of
> the code is checking if the new line intersect with other lines. To
> reduce the comparisons, it check the bounding boxes.
> By dissolving, I turned all the small lines into really, really big
> ones. Then all bounding boxes intercept and the algorithm does a whole
> lot more comparisons....
> 750 minutes of processing, 5% progress, reduction method.
> F
> On Tue, Jan 6, 2015 at 3:48 PM, Fábio Dias <fabio.dias at gmail.com> wrote:
>> Original:
>> GRASS 7.1.svn (brasil):~ > v.info map=tc10
>> | Mapset: terraclass |
>> | Location: brasil |
>> | Database: /home/externo/fabioasd/grass |
>> | Title: |
>> | Map scale: 1:1 |
>> | Name of creator: fabioasd |
>> | Organization: |
>> | Source date: Sat Jan 3 23:38:40 2015 |
>> | Timestamp (first layer): none |
>> | Map format: native |
>> | Type of map: vector (level: 2) |
>> | Number of points: 0 Number of centroids: 5323741 |
>> | Number of lines: 0 Number of boundaries: 12889264 |
>> | Number of areas: 5573197 Number of islands: 1332382 |
>> | Map is 3D: No |
>> | Number of dblinks: 1 |
>> | Projection: Latitude-Longitude |
>> | N: 5:16:18.443667N S: 18:02:29.687783S |
>> | E: 43:59:58.760386W W: 73:59:29.009623W |
>> | Digitization threshold: 0 |
>> | Comment: |
>> After dissolve:
>> | Location: brasil |
>> | Title: |
>> | Map scale: 1:1 |
>> | Organization: |
>> | Number of points: 0 Number of centroids: 5120039 |
>> | Number of lines: 0 Number of boundaries: 12641473 |
>> | Number of areas: 5369494 Number of islands: 1366321 |
>> | Map is 3D: No |
>> | Comment: |
>> On Mon, Jan 5, 2015 at 5:49 PM, Fábio Dias <fabio.dias at gmail.com> wrote:
>>> Just for further reference, the v.dissolve takes around 24h in this
>>> dataset. I'll post the v.info of both as soon as it is finished.
>>> Any other ideas? I have a fairly powerful server at my disposal, but
>>> I'm out of ideas...
>>> On Sun, Jan 4, 2015 at 7:45 PM, Fábio Dias <fabio.dias at gmail.com> wrote:
>>>> As promised, profile of v.generalize, as of r63952.
>>>> (The data might not be exactly the same, I might have run v.clean somewhere).
>>>> I still have the raw profiles, if anyone wants them.
>>>> F
>>>> On Sun, Jan 4, 2015 at 6:01 PM, Fábio Dias <fabio.dias at gmail.com> wrote:
>>>>> Attached is pdf generated with google-perf of v.generalize, using
>>>>> g7b4. I'm running it again for trunk.
>>>>> On Sun, Jan 4, 2015 at 5:54 PM, Markus Metz
>>>>> <markus.metz.giswork at gmail.com> wrote:
>>>>>> On Wed, Dec 31, 2014 at 5:20 PM, Fábio Dias <fabio.dias at gmail.com> wrote:
>>>>>>> I fussed about the v.generalize code, thinking about pthread
>>>>>>> parallelization. The geometry part of the code is *really* fast and
>>>>>>> can be easily parallelized so it can run even faster. But, according
>>>>>>> to the profile google-perf gave me, the real bottleneck is inside the
>>>>>>> check_topo function (which uses static vars and inserts a new line
>>>>>>> into the vector, not only checks if it breaks topo - got stuck a while
>>>>>>> in there due to the misnomer). More specifically in the Rtree function
>>>>>>> used to check if one line intersects other lines.
>>>>>> The function used in check_topo is Vect_line_intersection() which does
>>>>>> much more than just testing for intersections. The process could be
>>>>>> made much faster if Vect_line_check_intersection() would be modified
>>>>>> such that connections by end points are ignored. But I don't know if
>>>>>> this would break other modules or other functionality.
>>>>>> Markus M
