[GRASS-user] Correcting data errors
Fábio Dias
fabio.dias at gmail.com
Sat Jan 10 10:34:52 PST 2015
Hello again,
This issue "arised" from my other thread ('v.generalize: does it take
forever?'). Since I think it would be bad practice to mix issues on
the same thread, I'm opening this one.
I have a dataset that corresponds to land usage on the 'legal amazon
region', the region that are legally recognized as related to the
amazon forest, even if there's not much there at the moment. This
dataset contain information of this region for 3 years already (2008,
2010, 2012) and 2014 is underway.
However, in the process of developing a web interface for this
dataset, I had the need to generalize that information, to reduce the
volume of data considering the current viewport. AFAIK, the only
proper way of doing that is topologically, so you don't end up with
gaps and overlaps.
PostGIS can do something like this, on the 2+ version, but my problem
is that the data is full of topological errors. I can't really call
them 'data errors', since the toolchain considered when the dataset
was created didn't have these restrictions. I'm going further than it
was expected when the process started. But they are topological errors
that I need to deal with.
As far as I saw, there are gaps between polygons, self-intersections,
bridges, etc etc. I'm fairly certain that there is at least one
occurrence of each type of error known to man. Matter of fact, a lot
of the polygons are not ST_Valid either.
I've read the manual and fussed with v.clean, trying with bpol, break,
rmdupl, etc. But I still don't really have the feeling that I know
what I'm doing. I lack experience with this, so:
TL;DR:
What would be the 'recommended' way of dealing with the 'errors' made
when the data is created with zero topological restrictions (and saved
as .shp?)
Thanks again,
F
Fábio Augusto Salve Dias
http://sites.google.com/site/fabiodias/
