[GRASS-user] v.generalize: does it take forever?
Markus Metz
markus.metz.giswork at gmail.com
Mon Jan 26 01:22:51 PST 2015
On Mon, Jan 26, 2015 at 9:30 AM, Markus Metz
<markus.metz.giswork at gmail.com> wrote:
> On Sun, Jan 25, 2015 at 6:11 PM, Fábio Dias <fabio.dias at gmail.com> wrote:
>> Hi,
>> Running r64249, with a couple of stuff in parallel using &. It seems
>> to be considerably slower.
> Very strange. Are you using trunk or GRASS 7.0?
Here, v.generalize on a TerraClass tile is down from 25 minutes to 13 seconds.
>> More than 100h, no 1% printed. To be fair,
>> I'm not entirely sure I'll see it when it prints, 10 v.generalize
>> running (5 for each year) + 1 v.in.ogr for 2012. That v.in.ogr is
>> running for almost 100h too. I'm loading the shps directly, as advised
>> way, way back in this thread.
> What exactly do you mean with "loading shps directly"? For
> v.generalize, you should import them with v.in.ogr.
> What about memory consumption on your system? With 10 v.generalize + 1
> v.in.ogr on such a big dataset, quite a lot of memory would be used.
> Markus M
>> AFAIK, no disk is been used, the whole thing is cached (after more
>> than 24h processing, cumulative iotop shows only a few mb
>> written/read). I'm no longer using a ramdisk for the grassdata dir.
>> However, it appears to be considerably slower, probably because of the
>> parallel running jobs.
>> My question then would be, considering the thread I saw about sqlite,
>> should I be using something else as backend? When it starts to make
>> sense to change it?
>> F
>> Fábio Augusto Salve Dias
>> ICMC - USP
>> http://sites.google.com/site/fabiodias/
>> On Wed, Jan 14, 2015 at 1:06 PM, Markus Neteler <neteler at osgeo.org> wrote:
>>> On Wed, Jan 14, 2015 at 3:54 PM, Fábio Dias <fabio.dias at gmail.com> wrote:
>>>> What would be the best way to do that in parallel? One mapset for each
>>>> year? Can I run multiple v.generalizes on the same input with
>>>> different outputs?
>>> Yes sure.
>>>> My first thought was to run completely separated grass processes for
>>>> each simplification, but I didn't find a way to make it search
>>>> something different than .grass / .grass70 for the configuration
>>>> stuff....
>>> Maybe take a look at this approach
>>> http://grasswiki.osgeo.org/wiki/Parallel_GRASS_jobs#Grid_Engine
>>> but even sending different v.generalize jobs to background (&) should
>>> work if you have enough RAM.
>>> markusN
