[GRASS-user] filtering csv file before input for v.in.ascii
Veronica Andreo
veroandreo at gmail.com
Wed Jul 1 00:13:22 PDT 2015
Hi Helmut,
Did you download from GBIF site? Because there are 2 (that I know) R
packages that allows you to download data from GBIF, and you can ask for
"NO SPATIAL ISSUES" in the data (among other options), probably in that way
you can avoid these coordinates that are in a different reference system.
Does that make sense?? Ah! The packages are: rgbif and dismo
If you want, I can provide an example... I just tried yesterday :)
HTH,
Vero
2015-06-27 10:16 GMT-03:00 Helmut Kudrnovsky <hellik at web.de>:
> Markus Neteler wrote
> > On Tue, Jun 16, 2015 at 10:51 PM, Helmut Kudrnovsky <
> > hellik@
> > > wrote:
> >> hi,
> >> given data in csv format with columns e.g. xcoor, ycoor and a few other
> >> as
> >> input for v.in.ascii where some rows may have an empty entry in xcoor,
> >> ycoor.
> >> the idea for a little script wrapper for v.in.ascii:
> >> filter the input file by empty xcoor, ycoor, then forward the
> >> modified/filtered csv to v.in.ascii
> > Did you see the "new" flag of v.in.ascii
> > -i Ignore broken line(s) in points mode
> > ? For us it did the job on a lot of data sets.
> > Markus
> _-i Ignore broken line(s) in points mode_ doesn't work here.
> it's GBIF data file (attached an short example: test.csv, and a modified
> one
> by quoting the entries: test2.csv). GBIF data is"usually" in WGS84.
> some xcoor, ycoor in this sample dataset are empty or where some xcoor,
> ycoor have coordinates for some other coordinate systems not matching
> WGS84.
> so some coordinate pairs are out of range for a ll-location.
> test.csv <http://osgeo-org.1560.x6.nabble.com/file/n5213229/test.csv>
> test2.csv <http://osgeo-org.1560.x6.nabble.com/file/n5213229/test2.csv>
> best regards
> Helmut
> http://osgeo-org.1560.x6.nabble.com/filtering-csv-file-before-input-for-v-in-ascii-tp5211340p5213229.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150701/65b3d607/attachment.html>
