[GRASS-user] Exporting a raster tiff with RGB 3 bands produce a paletted tiff
Andrea Peri
aperi2007 at gmail.com
Thu Jul 2 07:23:31 PDT 2015
Hi Markus,
thx for hint.
I tried but probably I miss something.
because have an error:
>ERROR 6: SetColorTable() not supported for multi-sample TIFF
>files.
>ERROR 6: SetColorTable() can only be called on band 1.
I defined a group named "gruppo" and insert in it the three raster I
like to have for the three bands.
After I execute this command:
r.out.gdal -f --overwrite input=gruppo
output=D:\temp\hpf_out_rescale2.tif format=GTiff type=Byte
createopt=INTERLEAVE=PIXEL,TFW=YES,PROFILE=BASELINE,COMPRESS=DEFLATE
This is the results log:
WARNING: Perdita di precisione: mappa raster
<LC81920292015157LGN00_reflect2.hpf> di tipo DCELL da esportare come
Byte. Può essere evitata usando Float64.
<LC81920292015157LGN00_reflect3.hpf> di tipo DCELL da esportare come
<LC81920292015157LGN00_reflect4.hpf> di tipo DCELL da esportare come
WARNING: Si sta forzando l'esportazione del raster.
Checking GDAL data type and nodata value...
Using GDAL data type <Byte>
La mappa raster di input contiene celle con valore NULL (nessun dato).
Il valore 255 verrà usato per rappresentare i valori delle celle senza
dati nella mappa di input. È possibile specificare un valore per le
celle senza dati con l'opzione nodata.
files.
Exporting raster data to GTiff format...
r.out.gdal completo. File <D:\temp\hpf_out_rescale2.tif> created.
Thx,
A.
2015-07-02 12:56 GMT+02:00 Markus Neteler <neteler at osgeo.org>:
> Hi,
> On Jul 2, 2015 11:58 AM, "Andrea Peri" <aperi2007 at gmail.com> wrote:
>> Hi,
>> I'm try-ing to export a raster RGB using this command:
> If you have the three RGB channels, you can export via a group:
> http://grass.osgeo.org/grass70/manuals/r.out.gdal.html#export-r,g,b-imagery-bands-in-geotiff-format-suitable-for-esri-software:
> Best
> Markus
Andrea Peri
qwerty àèìòù
