[GRASS-user] i.atcorr whit Aster Data - null value - WARNING: Unknown atmospheric model!....
Gabriele N. gis.gn at libero.it
Mon Jul 13 04:58:27 PDT 2015
I have a problem with i.atcorr with data aster.  I tried it with grass 64
and 7, on ubuntu 15.04 64-bit.
Maybe I'm wrong to set the parameters of the txt? (Is there anyone can tell
me if they are correct? I have attached the file .met)...Otherwise I do not
know.....
/10                           - geometrical conditions=ASTER
01 16 15.28 -74.9 -14.8      - month day hh.ddd longitude latitude ("hh.ddd"
is in GMT decimal hours)
2                            - atmospheric mode=midlatitude summer
1                            - aerosols model=continental
15                           - visibility [km] (aerosol model concentration)
-0.121                       - mean target elevation above sea level [km]
-1000                        - sensor on board a satellite
72                           - aster band 1 (0.480-0.645) /
The result I get is always with null values.
/ |   Total Cells:  27293388
 |        Projection: UTM (zone 18)
 |            N: -1605247.26436317    S: -1678867.26436317   Res:    15
 |            E: 552980.14168175    W: 469565.14168175   Res:    15
 |   Range of data:    min = -nan  max = -nan
In the output window:
wavelength  less  than  0.25  micron:
 let's take s(l)=s(0.25)
WARNING: Unknown aerosol model!/
Only in some cases there is a warning wavelength.
Here there is the file .met
AST_L1B_00301162001152851_20150713051848_23493.met
<http://osgeo-org.1560.x6.nabble.com/file/n5215412/AST_L1B_00301162001152851_20150713051848_23493.met>
I've seen other threads such as Yann but I did not understand the problem
http://osgeo-org.1560.x6.nabble.com/i-atcorr-with-Aster-td3997467.html
Thank you
View this message in context: http://osgeo-org.1560.x6.nabble.com/i-atcorr-whit-Aster-Data-null-value-WARNING-Unknown-atmospheric-model-tp5215412.html
Sent from the Grass - Users mailing list archive at Nabble.com.
