[GRASS-user] function doesn't work anymore
    Gra
    graziaz at gmail.com
    Tue Jul 14 07:41:33 PDT 2015
Hi this function
Hi this function:
def normalize (inras,outras):
min = grass.raster_info(inras)['min']
max = grass.raster_info(inras)['max']
grass.mapcalc("$outras = float(($inras -$valuem) / ($valueM-$valuem))",
inras = inras, outras = outras, valuem = min,valueM = max, overwrite=True)
grass.run_command('g.remove', flags='f', type='raster', name=inras,
quiet=True)
apparently the syntax changed for min = grass.raster_info(inras)['min']
could you help
thanks
Grazia
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150714/b0f8cdb7/attachment.html>
