[GRASS-user] The export r.out.gdal reduce the resolution of the result from i.fusion.hpf script
Anna Petrášová
kratochanna at gmail.com
Sun Jul 26 22:43:34 PDT 2015
On Jul 26, 2015 12:05 PM, "Andrea Peri" <aperi2007 at gmail.com> wrote:
> Hi,
> Starting on grass 7.0.
> I try to use the
> i.fusion.hpf script to create a new panchromatic image.
> Starting with a raster (from landsat) 30meters and a panchromatic
15meters.
> With the i.fusion.hpf I produce a new raster at high resolution
(15meters).
> The verify that really it has 15m , I open it with the grass display
> and measure che legth of the pixel.
> Ok, it is really 15meters.
> After this I try to export the new raster with the r.gdal.out.
> This is the command I run:
> (the LC81920302015157LGN00_B4.org_hpf at andrea is the new 15meter raster)
> r.out.gdal -f --verbose input=LC81920302015157LGN00_B4.org_hpf at andrea
> output=D:\temp\exported_image.tif format=GTiff type=Float64
> createopt=INTERLEAVE=PIXEL,TFW=YES,PROFILE=BASELINE,COMPRESS=DEFLATE
> This is the log of execution:
> Esportazione al tipo di dato GDAL: Float64
> Checking GDAL data type and nodata value...
> ERROR 6: SetColorTable() only supported for Byte or UInt16
> bands in TIFF format.
> Using GDAL data type <Float64>
> Input raster map contains cells with NULL-value (no-data). The value
> nan will be used to represent no-data values in the input map. You can
> specify a nodata value with the nodata option.
> Exporting raster data to GTiff format...
> WARNING: Too many values, color table cut to 65535 entries
> r.out.gdal completo. File <D:\temp\exported_image.tif> created.
> I notice the warning for too many values.
> But really I don't understand what it mean because this is a float
> raster and not an integer raster.
> When I go to test the new exported tif image with qgis.
> I see the pixel size is now 30meters and not 15meters.
> How is possibile that the r.gdal.out could reduce the resolution of the
image ?
> This is really uncomprensible to me.
> Is this a knowed issue ?
> Any help is welcome.
Is it possible your computational region is set to 30 m resolution? Try
g.region -p. r.out.gdal respects region settings.
> Thx.
> Andrea Peri
> qwerty àèìòù
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150727/e9f64834/attachment.html>
