[GRASS-user] GRASS-7svn: Specify wxPython Version
Rich Shepard
rshepard at appl-ecosys.com
Mon Jul 27 09:00:26 PDT 2015
On Mon, 27 Jul 2015, Carlos Grohmann wrote:
> maybe something like
> --with-wxwidgets=/usr/local/lib/wxPython-3.0.2.0/bin/wx-config \
> during configure?
Carlos,
The configuration file contains the line
--with-wxwidgets=/usr/bin/wx-config
and wx-config has a way of specifying a version using a mask:
# get_mask [ _hash ]
# Construct a config filename mask from a pseudo-hash of component variable
s.
# The optional argument is the prefix of the hash to use. If not specified
# this will return a mask derived from the command line options that were u
sed.
get_mask()
[ $# -gt 0 ] || set m
case "$m_ourversion" in
2.9)
is29orlater=1
2.*)
# there is no 2.10 so currently everything else is <= 2.8
is29orlater=0
# 3.x and later "is29orlater" too
is29orlater=1
esac
# use 2.8 or 2.9 version of the mask: the difference is the presence of
# debug type in pre-2.9
if [ $is29orlater = 0 ]; then
eval echo
"\${$1_host:+\$$1_host-}\${$1_toolkit}\${$1_widgetset}-\${$1_chartype}-\${$1_debugtype}\${$1_linkage:+-\$$1_linkage}-\${$1_version}\${$1_flavour}"
else
eval echo
"\${$1_host:+\$$1_host-}\${$1_toolkit}\${$1_widgetset}-\${$1_chartype}\${$1_linkage:+-\$$1_linkage}-\${$1_version}\${$1_flavour}"
fi
So there ought to be a way to pass 'is29orlater=1' on the configuration
line, but I've no idea how to do this.
Thanks,
Rich
