[GRASS-user] v.neighors error:region do not overlap
patrick s. patrick_gis at gmx.net
Wed Jul 29 07:40:23 PDT 2015
I need to run v.neighbors on multiple datasets for the identic region
(extend and resolution).  One dataset has observations outside of this
region, and causes an error: "ERROR: Input vector and computational
region do not overlap." However, viewing the extend in v.info and r.info
(see below) and overlaying the layers in the GUI, I see overlaps for 90%
of my points. Is this expected behavior or do I miss something? (GRASS70
from Repos, OS:Ubuntu 15.04)
#Code
/r.in.gdal in="./00_REFERENCE/reference_map.tif" out=region_ref --o//
//g.region rast=region_ref//
//v.neighbors in=pt out=pt_dens300 size=600 meth=count --overwrite //
#extract of "v.info pt":
  | Title:
  | Map scale:       1:1
  | Map format:      native
  |   Type of map: vector (level: 2)
  |   Number of points:       10278           Number of centroids: 0
  |   Map is 3D: No
  |   Number of dblinks: 1
  |   Projection: Swiss. Obl. Mercator
  |               N:  1309490.94577888    S: 1060967.94534242
  |               E:  2906024.04080627    W: 2424801.03992381
  |   Digitization threshold: 0
#extract of "r.info region_ref":
  |   Type of Map:  raster               Number of Categories: 0
  |   Data Type: CELL
  |   Rows: 8912
  |   Columns: 14016
  |   Total Cells: 124910592
  |            N:    1297000    S:    1074200   Res: 25
  |            E:    2834800    W:    2484400   Res: 25
  |   Range of data:    min = 1  max = 999
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150729/9cfdc326/attachment-0001.html>
