[GRASS-user] i.atcorr for GeoEye-1 and Worldview-3
    Kamhul Camhol
    monk_purple at yahoo.com
    Thu Jun  4 03:11:34 PDT 2015
Dear Moritz,
Yes, for GeoEye-1 and Worldview-3, the: A) geometric conditions and F) band values, two of the required inputs/parameters for the GRASS i.atcorr 6S  algorithm.
Thank you. Sincerely,
Armand
     On Thursday, June 4, 2015 5:38 PM, Moritz Lennert <mlennert at club.worldonline.be> wrote:
 On 03/06/15 15:06, Markus Neteler wrote:
> On Wed, Jun 3, 2015 at 6:56 AM, Kamhul Camhol <monk_purple at yahoo.com> wrote:
>> Hello. I'm quite new with GRASS but I need to atmospherically process
>> high-resolution imagery with i.atcorr. I have three images Quickbird,
>> GeoEye-1 and Worldview-3 imagery of a single scene across three time
>> periods. For Quickbird, I have all the data needed but basing from the
>> following manual GRASS GIS manual: i.atcorr
>> there appears to be no values for two required inputs for GeoEye-1 and
>> Worldview-3.
> Yes, at time only Quickbird but not GeoEye-1 and Worldview-3 are supported.
>> These are geometrical conditions and band. May I know if GRASS
>> has updated the i.atcorr manual to include these sensors as well? Can I use
>> the values of Worldview-2 for Worldview-3? Or is there any other way to do
>> the atmospheric correction for these two sensors?
> We would be happy to add support for these sensors. We need the
> spectral filter curves for that, in order to integrate them in
> i.atcorr.
Do I understand correctly that you would need the numbers behind the
curves in this document:
https://www.digitalglobe.com/sites/default/files/DigitalGlobe_Spectral_Response_1.pdf
Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150604/4284a599/attachment.html>
