[GRASS-user] Issue with netcdf import into GRASS 7
Thomas Adams
tea3rd at gmail.com
Mon Jun 8 19:47:49 PDT 2015
All:
Using the help found here: http://grasswiki.osgeo.org/wiki/NetCDF I have
been able to import a netcdf file into GRASS 7, but the data is not scaled
correctly.
My file is found here:
https://drive.google.com/file/d/0B-Dmtz0DFEiubG5aYTk4TDZERXc/view?usp=sharing
I created a GRASS LOCATION based on this:
char Lambert;
:grid_mapping_name = "lambert_conformal_conic";
:latitude_of_projection_origin = 37.99999237060547; // double
:longitude_of_central_meridian = -106.0; // double
:standard_parallel = 34.0, 42.0; // double
:earth_radius = 6371229.0; // double
:_CoordinateTransformType = "Projection";
:_CoordinateAxisTypes = "GeoX GeoY";
which I obtained using panoply from here:
http://www.giss.nasa.gov/tools/panoply/
Looking at the file netcdf header information, it's clear the
dx=dy=1000m; but, what imports is x=dy=1m resolution even though I set
the x & y resolution to 1000m
This is my import command:
r.in.gdal input=NETCDF:"geo_em.d02.nc":GREENFRAC output=greenfrac -o
-e --overwrite
which produces..
Warning 1: No UNIDATA NC_GLOBAL:Conventions attribute
WARNING: Over-riding projection check
100%
Raster map <greenfrac.1> created.
100%
Raster map <greenfrac.2> created.
100%
Raster map <greenfrac.3> created.
100%
Raster map <greenfrac.4> created.
100%
Raster map <greenfrac.5> created.
100%
Raster map <greenfrac.6> created.
100%
Raster map <greenfrac.7> created.
100%
Raster map <greenfrac.8> created.
100%
Raster map <greenfrac.9> created.
100%
Raster map <greenfrac.10> created.
100%
Raster map <greenfrac.11> created.
100%
Raster map <greenfrac.12> created.
Region for the current mapset updated
r.in.gdal complete.
I am virtually certain the lower left corner is placed correctly, because I
can zoom to the lower-left location and it falls about where it should --
however the spatial extent of the data is not what it should be, but when
zoomed-in looks correct.
Any thoughts?
Thank you,
Tom
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150608/ddca4246/attachment.html>
