[GRASS-user] Low reflectance values with i.atcorr and Landsat 8
John, Lisa
lisa.john at stud.uni-goettingen.de
Mon Jun 15 05:25:34 PDT 2015
Hi Micha,
did you refer to the input range?
I did so and checked bands 1-9 with r.info -r. Top of atmosphere reflectance values are all in the range of -0.01 - 2.12. The negative value seems to be a outlier and I check in addition with the range 0-2.12.
I used these values for the input range in i.atcorr -r and used 0,1 as output range.
However I get even smaller reflectance values (0.15 respectively 0.29 for vegetation in band5)
Regards, Lisa.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150615/b05c256e/attachment.html>
