[GRASS-user] Low reflectance values with i.atcorr and Landsat 8
Yann Chemin
ychemin at gmail.com
Tue Jun 16 20:45:35 PDT 2015
Something is fishy here, reflectance values should always be within 0-1
range.
Please manually remove all values outside of that range (use r.mapcalc) and
make a histogram of your TOAR band. if the histogram is of expected shape,
and is not truncated at 1.0 threshold then you are OK. if there is a
problem here, that means the TOAR processing had an issue. Stretching
output from an unknown histogram skewness could be giving you funny results.
On Mon, Jun 15, 2015 at 6:47 PM Micha Silver <micha at arava.co.il> wrote:
> On 6/15/2015 3:25 PM, John, Lisa wrote:
> Hi Micha,
> did you refer to the input range?
> Yes, the input range.
> I did so and checked bands 1-9 with r.info -r. Top of atmosphere
> reflectance values are all in the range of -0.01 - 2.12. The negative value
> seems to be a outlier and I check in addition with the range 0-2.12.
> I used these values for the input range in i.atcorr -r and used 0,1 as
> output range.
> I meant in the first i.landsat.toar step. The input (DN) values should be
> up to 700 or so. Landsat 8, with its 12 bit data can have max DN values of
> 4096. But I didn't use that full range, rather the actual DN range of the
> original images.
> However I get even smaller reflectance values (0.15 respectively 0.29 for
> vegetation in band5)
> Regards, Lisa.
> This mail was received via Mail-SeCure System.
> grass-user mailing listgrass-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150617/943a33ff/attachment.html>
