[GRASS-user] Compiling grass 7 on debian 7.8 64bit
Andrea Peri aperi2007 at gmail.com
Fri Jun 19 14:45:14 PDT 2015
I found the response in this document:
http://grasswiki.osgeo.org/wiki/Compile_and_Install#GRASS_7_on_Debian_Wheezy
Really useful.
Regards,
A.
2015-06-19 10:40 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
> Hi,
> I'm new to the Grass ML, so before all I'm glad to to say a big Hello
> to every grass user.
> I'm try-ing to compile the grass 7 from sources on a Debian 64 bit platform.
> I have previously installed all the dependencies requested. Also I
> pass well the configuration phase.
> Just a little puntualizzation on the configuration phase:
> The INSTALL doc say to use the "enable-64bit" parameter, but the
> configure refuse it saying unknowed parameter.
>>To fully enable 64bit library usage for GRASS on 64bit platforms,
>>the following additional parameters are recommended/required:
>>    ./configure \
>>       --enable-64bit \
>>       --with-libs=/usr/lib64 \
> But this is not problem.
> Instead after this, when I go to the "make" phase, I have many error
> in several folders.
> like this:
> make: /home/archivio/tomcat/software/grass/grass-7.0.0/dist.x86_64-unknown-linux-gnu/tools/g.echo:
> Command not found
> Command not found
> make OBJ.x86_64-unknown-linux-gnu/current_time_s_ms.manifest.res &&
> gcc -L/home/archivio/tomcat/software/grass/grass-7.0.0/dist.x86_64-unknown-linux-gnu/lib
> -L/usr/lib64/ -Wl,--export-dynamic  -L/usr/lib
> -Wl,-rpath-link,/home/archivio/tomcat/software/grass/grass-7.0.0/dist.x86_64-unknown-linux-gnu/lib
>  -o /home/archivio/tomcat/software/grass/grass-7.0.0/dist.x86_64-unknown-linux-gnu/etc/current_time_s_ms
> OBJ.x86_64-unknown-linux-gnu/main.o
> OBJ.x86_64-unknown-linux-gnu/current_time_s_ms.manifest.res   -lm
> make[1]: /home/archivio/tomcat/software/grass/grass-7.0.0/dist.x86_64-unknown-linux-gnu/tools/g.echo:
> Command not found
> I check effectively that the g.echo is not available in the
> dist.x86_64-unknown-linux-gnu/tools folder
> I'm not sure this is an issue, I guess instead that perhaps I'm
> missing some extra code to download or instead the grass source code
> available in the site is not suitable for the debian distro.
> There some specific settings or depedencies for compile on debian 64bit ?
> I'm using the Debian 7.8  - 64bit.
> Many thx.
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
