[GRASS-user] How work the "-c" option of grass text
Andrea Peri aperi2007 at gmail.com
Sun Jun 21 15:44:47 PDT 2015
I'm trying to create a batch procedure that create a "mapset" and load
some rasters on it.
To do this I'm studyng the "-c" option of grass70 textual start.
But I'm not sure to undertsand how it work.
Infact if I try this command:
grass70 -text -c /path-raster/immagine.tif  /path-grassdata/test_location -e
The grass give me an error.
Instead if I try this other command:
/path-grassdata/test_location/test-mapset -e
The grass give no error and close regularly.
Bu the result is not correct for me.
Infact it  produce a new folder named "test_location" and inside the
"permanent" folder.
Instead I guess it should produce the folder "test_location" and the
"permanent" at the same level of the "test_location".
Surely I'm wrong something but I'm not clear what.
any hint is welcome.
Andrea Peri
qwerty àèìòù
