[GRASS-user] How work the "-c" option of grass text
Andrea Peri
aperi2007 at gmail.com
Mon Jun 22 00:13:40 PDT 2015
Hi Vaclav,
thx for your response.
I tested your solution but the grass still give me an error:
I try this:
mkdir /home/archivio/dati/raster/landsat/applicazione/temp/grassdata
mkdir /home/archivio/dati/raster/landsat/applicazione/temp/grassdata/toscana_location
grass70 -text -c
/home/archivio/dati/raster/landsat/applicazione/temp/LC81930292015164LGN00/LC81930292015164LGN00_B1.TIF
-e /home/archivio/dati/raster/landsat/applicazione/temp/grassdata/toscana_location
and the grass return this error:
Creating new GRASS GIS location/mapset...
access: No such file or directory
ERROR: LOCATION
</home/archivio/dati/raster/landsat/applicazione/temp/grassdata/<UNKNOWN>>
not available
ERROR: Path '/home/archivio/dati/raster/landsat/applicazione/temp/grassdata/toscana_location/PERMANENT'
doesn't exist
Exiting...
Many thx,
A.
2015-06-22 1:32 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> Hi Andrea,
> quick but untested answer:
> On Sun, Jun 21, 2015 at 6:44 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
>> grass70 -text -c /path-raster/immagine.tif /path-grassdata/test_location
>> -e
> grass70 -e -c /path-raster/immagine.tif /path-grassdata/test_location
> According to --help, the Location path must be the last parameter.
> Although now I see that --help might not be precise about path to Location
> versus path to Mapset in case of -c. Some bash scripts to test this stuff
> would be needed as well.
> Since you are using this API, keep an eye on what is happening in trunk now:
> http://grass.osgeo.org/grass71/manuals/grass7.html#exec-interface-example
> https://lists.osgeo.org/pipermail/grass-user/2015-June/072511.html
> https://trac.osgeo.org/grass/ticket/2579
Andrea Peri
qwerty àèìòù
