[GRASS-user] Error trying to compile grass 7 w/libLAS Debian Jessie
    César Augusto Ramírez Franco
    caesarivs at gmail.com
    Wed Jun 24 14:08:21 PDT 2015
Hello dear list
I'm trying to compile grass 7 from source on Debian Jessie with libLAS
support, here's what I've tried:
I've installed liblas-bin and liblas-dev (1.8.0) from debian repositories
Downloaded grass source code:
wget http://grass.osgeo.org/grass70/source/grass-7.0.0.tar.gz
tar xzf grass-7.0.0.tar.gz
cd grass-7.0.0
But when I run
./configure ... --with-liblas=yes
I get:
checking for liblas-config... /usr/bin/liblas-config
configure: error: *** Unable to locate libLAS library.
Here's the config.log:
configure:6164: checking whether to use libLAS
configure:6181: checking for liblas-config
configure:6238: gcc -o conftest -g -Wall
-Werror-implicit-function-declaration -
fno-common -Wextra -Wunused  -g -O2 -fstack-protector-strong -Wformat
-Werror=fo
rmat-security -D_FORTIFY_SOURCE=2  -I/usr/include -I/usr/include/gdal
-I/usr/inc
lude/geotiff -I/usr/include/i386-linux-gnu  -Wl,--export-dynamic conftest.c
 -L/
usr/lib -llas -llas_c -L/usr/lib/i386-linux-gnu
/usr/lib/i386-linux-gnu/libboost
_program_options.so /usr/lib/i386-linux-gnu/libboost_thread.so
/usr/lib/libgdal.
so /usr/lib/libgeotiff.so /usr/lib/i386-linux-gnu/libtiff.so 1>&5
gcc: error: /usr/lib/libgeotiff.so: No such file or directory
configure: failed program was:
#line 6231 "configure"
#include "confdefs.h"
#include <liblas/capi/liblas.h>
int main() {
LASReader_Create("foo");
; return 0; }
configure:6253: gcc -o conftest -g -Wall
-Werror=fo
-I/usr/inc
 -L/
/usr/lib/libgdal.
#line 6246 "configure"
int main() {
; return 0; }
I tried checking out from SVN too:
svn checkout https://svn.osgeo.org/grass/grass/branches/releasebranch_7_0
grass-7.0.svn
cd grass-7.0.svn
And I get the same error
I found a ticket (http://trac.osgeo.org/grass/ticket/2065) about this but
it's marked as fixed...
Can someone please guide me as to how to bypass this error?
The full configure options are:
CFLAGS="-g -Wall -Werror-implicit-function-declaration -fno-common -Wextra
-Wunused" CXXFLAGS="-g -Wall" \
./configure \
   --prefix=/usr/local \
   --with-gdal \
   --with-proj --with-proj-share=/usr/share \
   --with-glw --with-nls --with-readline \
   --with-cxx --enable-largefile \
   --with-freetype --with-freetype-includes=/usr/include/freetype2 \
   --with-sqlite --with-cairo --with-python=/usr/bin/python-config \
   --with-wxwidgets --with-geos --with-blas \
   --with-lapack-includes=/usr/lib/lapack --with-liblas=yes \
   --with-netcdf=/usr/bin/nc-config --with-odbc=yes \
   --with-openmp=yes --with-pthread=yes --with-postgres=yes \
   --with-postgres-includes=/usr/include/postgresql \
   --with-postgres-libs=/usr/lib/postgresql \
   --with-mysql=yes --with-mysql-includes=/usr/include/mysql \
   --with-mysql-libs=/usr/lib/mysql
Thanks!
*César Augusto Ramírez Franco*
Laboratorio de Sistemas Complejos Naturales
Escuela de Geociencias
Facultad de Ciencias
Universidad Nacional de Colombia - Sede Medellín
Teléfono: (57-4) 430 9369 - 300 459 6085
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150624/c00657ad/attachment.html>
