[GRASS-user] Error in pansharp tool: missing grass.script
Andrea Peri aperi2007 at gmail.com
Thu Jun 25 14:40:28 PDT 2015
I report the last tests:
2015-06-25 15:15 GMT+02:00 Vaclav Petras <wenzeslaus at gmail.com>:
> /usr/bin/env python -c "import sys; print(sys.path)"
~$ /usr/bin/env python -c "import sys; print(sys.path)"
['', '/usr/local/lib/python2.7/dist-packages/GDAL-2.0.0-py2.7-linux-x86_64.egg',
'/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
'/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload',
'/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages/PIL',
'/usr/lib/pymodules/python2.7',
'/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode']
I use the panshapen tools outside from grass.
I set all the Grass env vars  and call the grass tools.
Is this a wrong use ?
I choose this solution because need to write a batch to process
periodically from a cron .
A.
Andrea Peri
qwerty àèìòù
