[GRASS-user] not able to import and use pygrass
    Moritz Lennert
    mlennert at club.worldonline.be
    Mon Jun 29 08:42:18 PDT 2015
On 29/06/15 16:57, Gra wrote:
> Hi I compiled Grass 7.0 (with OpenMP) on a CENTOS 7 OS.
> everything works properly, but I'm not able to use PYGRASS
> here is my first part of the codes if I add import pygrass I have the error:
>      import pygrass
> ImportError: No module named pygrass
try
import grass.pygrass
pygrass is on the same level as script which you seem to be able to
import successfully.
Moritz
