[GRASS-user] Generating curvature map
Vaclav Petras wenzeslaus at gmail.com
Tue Jun 30 12:37:23 PDT 2015
On Tue, Jun 30, 2015 at 2:20 PM, Ahmet Temiz <ahmettemiz88 at gmail.com> wrote:
> I was wondering if it was possible to generate curvature map
> from DEM which is in LL wgs 84.
> Or
> Should I transform dem another projection?
r.slope.aspect manual doesn't say that it is not technically possible, but
certainly you should use a projected coordinate system. All raster
operations should be done in projected coordinate system, not LL.
Vaclav
http://grass.osgeo.org/grass70/manuals/r.slope.aspect.html
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150630/379b0702/attachment.html>
