[GRASS-user] GRASS 7.0 Running Scripts (.\GRASS GIS 7.0.0\scripts)
Vaclav Petras
wenzeslaus at gmail.com
Sun Mar 1 17:12:57 PST 2015
On Sun, Mar 1, 2015 at 7:37 PM, Rob Parsons <jrobparsons at gmail.com> wrote:
> Hello,
> How do I run scripts located in C:\Program Files (x86)\GRASS GIS
> 7.0.0\scripts?
> I am learning GRASS 7.0.0 on Windows 7 by converting some GRASS 6.4 shell
> scripts to GRASS 7 Python scripts (import grass.script as grass) and GRASS
> 7 PyGRASS scripts (from grass.pygrass.modules import Module).
> My installation is working fine. I can manually run the commands (from a
> shell script) in the "Command console" window of the "Layer Manager". For
> example, I can enter "g.region swwake_30m -p" in the "Command prompt" area
> and get the following results:
> Sun Mar 01 12:32:30
> 2015)
> g.region swwake_30m
> -p
> projection: 99 (Lambert Conformal Conic)
> zone: 0
> datum: nad83
> ellipsoid: a=6378137 es=0.006694380022900787
> north: 228500
> south: 215000
> west: 630000
> east: 645000
> nsres: 30
> ewres: 30
> rows: 450
> cols: 500
> cells: 225000
> (Sun Mar 01 12:32:31 2015) Command finished (0
> sec)
> I am using the "Pythonwin" IDE to develop the scripts (C:\Program Files
> (x86)\GRASS GIS 7.0.0\Python27\lib\site-packages\pythonwin\Pythonwin.exe).
> In the "GRASS GIS 7.0.0 GUI" Command Prompt window I type "pythonwin" and
> the IDE starts up.
> I have spent several days trying to understand how to create GRASS Python
> scripts and GRASS PyGRASS scripts from the online documentation(
> http://grasswiki.osgeo.org/wiki/GRASS_and_Python) and by studying the
> script samples (C:\Program Files (x86)\GRASS GIS 7.0.0\scripts). I have not
> been successful in getting example code to run but I am still working
> through the documentation.
> Please try the example from:
http://grass.osgeo.org/grass70/manuals/libpython/script_intro.html
I linked this page from documentation as well as the other Python wiki page
from the GRASS and Python page:
http://grasswiki.osgeo.org/wiki/GRASS_Python_Scripting_Library
Note that GRASS scripts by default cannot run from outside GRASS GIS
session (environment). This is probably not emphasized enough in the
documentation.
But, I should be able to run scripts located in C:\Program Files
> (x86)\GRASS GIS 7.0.0\scripts.
> Correct?
> Correct but can you please try some other module than a d.* module, e.g.
r.out.xyz? d.* commands are somehow special (although in this case it
probably doesn't matter).
> 1. If I open .\scripts\d.what.rast.py in the Pythonwin IDE and try to run
> it, I get this output:
> OSError error(9): The handle is invalid
> Traceback (most recent call last):
> File "C:\Program Files (x86)\GRASS GIS
> 7.0.0\Python27\lib\site-packages\pythonwin\pywin\framework\scriptutils.py",
> line 325, in RunScript
> exec codeObject in __main__.__dict__
> File
> "C:\Users\Rob\Documents\grassscripts\pygrass\make_raster_using_mapcalc.py",
> line 8, in <module>
> g.message("Filter elevation map by a threshold...")
> 7.0.0\etc\python\grass\pygrass\modules\shortcuts.py", line 46, in
> __getattr__
> return self.cls('%s.%s' % (self.prefix, name.replace('_', '.')))
> 7.0.0\etc\python\grass\pygrass\modules\interface\module.py", line 498, in
> __init__
> raise GrassError(str_err % self.name)
> GrassError: Error running: `g.message --interface-description`.
> File "C:\Program Files (x86)\GRASS GIS 7.0.0\scripts\d.what.rast.py",
> line 45, in <module>
> main()
> line 30, in main
> options, flags = gcore.parser()
> 7.0.0\etc\python\grass\script\core.py", line 680, in parser
> p = subprocess.Popen([prog, '-n'] + argv, stdout=subprocess.PIPE)
> 7.0.0\Python27\lib\subprocess.py", line 703, in __init__
> errread, errwrite) = self._get_handles(stdin, stdout, stderr)
> 7.0.0\Python27\lib\subprocess.py", line 839, in _get_handles
> p2cread = self._make_inheritable(p2cread)
> 7.0.0\Python27\lib\subprocess.py", line 878, in _make_inheritable
> _subprocess.DUPLICATE_SAME_ACCESS)
> WindowsError: [Error 6] The handle is invalid
> main()
> line 30, in main
This might be somehow related to bug in Python itself:
http://bugs.python.org/issue3905
However, please focus on running the scripts for GRASS GIS from GRASS
session. The easiest way how to do that on MS Windows is to write the
script and then to start it from GUI (File > Run script) or from Python
shell tab in the GUI.
It is possible to run scripts which are using GRASS modules from outside of
GRASS session but it requires you to set up the GRASS environment yourself.
This is possible but it has some challenges. On the other hand, if you
write your script in the way that it runs (only) in a GRASS session you can
use GRASS features for automatic building of interface and thus create a
true GRASS module.
> 2. If I go to the "Python shell" tab on the "Layer Manager" and do File ->
> Launch Script and browse to .\scripts\d.what.rast.py, I get this output:
> sec)
> Launching script 'C:\Program Files (x86)\GRASS GIS 7.0.0\scripts\
> d.what.rast.py'...
> 7.0.0\gui\wxpython\gui_core\forms.py", line 718, in OnRun
> gcmd.Command(cmd)
> 7.0.0\gui\wxpython\core\gcmd.py", line 397, in __init__
> _("Error: ") + self.__GetError()))
> core.gcmd
> GException
> Execution failed: 'd.what.rast map=elevation'
> Details:
> Error:
> The error message seems to be incomplete but in any case, please try with
r.out.xyz script and the example script from:
Vaclav
> Any ideas on what might be going on here?
> Rob Parsons
> Raleigh NC
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150301/6ff05a0b/attachment-0001.html>
