[GRASS-user] grass-user Digest, Vol 107, Issue 9
Rob Parsons
jrobparsons at gmail.com
Thu Mar 5 19:42:35 PST 2015
Yes.
I do get the "add the script path to GRASS_ADDON_PATH" prompt. After I say
'yes' to the prompt, the script runs successfully.
Thanks!
On Thu, Mar 5, 2015 at 1:14 PM, <grass-user-request at lists.osgeo.org> wrote:
> Send grass-user mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> http://lists.osgeo.org/mailman/listinfo/grass-user
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> grass-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of grass-user digest..."
> Today's Topics:
> 1. Re: grass-user Digest, Vol 107, Issue 2 (Anna Petr??ov?)
> Message: 1
> Date: Thu, 5 Mar 2015 13:14:05 -0500
> From: Anna Petr??ov? <kratochanna at gmail.com>
> To: Rob Parsons <jrobparsons at gmail.com>
> Cc: GRASS user list <grass-user at lists.osgeo.org>
> Subject: Re: [GRASS-user] grass-user Digest, Vol 107, Issue 2
> Message-ID:
> <CAE0EDEro0wnTAaLkgmwsvpZcUckXvXmzBUMcOv4J5qwW=
> qRZPg at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> On Wed, Mar 4, 2015 at 10:09 PM, Rob Parsons <jrobparsons at gmail.com>
> wrote:
> > Thanks for the direction!
> > I have successfully worked through the examples on
> > http://grass.osgeo.org/grass70/manuals/libpython/script_intro.html
> except
> > for the last one about adding a module interface to a script. I copied
> the
> > code into a python file named module_interface.py. After I File-> "Launch
> > script" and select module_interface.py, the module GUI pops up and
> prompts
> > for the raster inputs and output. But, after clicking on "Run", the
> script
> > reports the following message:
> Before the module dialog opens, you should get a dialog asking to add the
> script path to GRASS_ADDON_PATH. If you do it, you should be able to run
> the script. Did you get this dialog?
> Anna
> (Wed Mar 04 21:55:29
> > 2015)
> > module_interface araster=el_D782_6m at PERMANENT
> braster=el_D783_6m at PERMANENT
> > output=el_r_6m
> > 'module_interface' is not recognized as an internal or
> > external command,
> > operable program or batch file.
> > (Wed Mar 04 21:55:29 2015) Command finished (0
> > sec)
> > Anyone seen this message?
> > Rob Parsons
> > Raleigh NC
> > On Sun, Mar 1, 2015 at 8:13 PM, <grass-user-request at lists.osgeo.org>
> >> Today's Topics:
> >> 1. GRASS 7.0 Running Scripts (.\GRASS GIS 7.0.0\scripts)
> >> (Rob Parsons)
> >> 2. Re: GRASS 7.0 Running Scripts (.\GRASS GIS 7.0.0\scripts)
> >> (Vaclav Petras)
> >> Message: 1
> >> Date: Sun, 1 Mar 2015 19:37:59 -0500
> >> From: Rob Parsons <jrobparsons at gmail.com>
> >> To: grass-user at lists.osgeo.org
> >> Subject: [GRASS-user] GRASS 7.0 Running Scripts (.\GRASS GIS
> >> 7.0.0\scripts)
> >> Message-ID:
> >> CAFvPsPBH1xVpEgff15hxknY0qeeMUeehP9bucV4FB9ZgQ_2+cg at mail.gmail.com>
> >> Hello,
> >> How do I run scripts located in C:\Program Files (x86)\GRASS GIS
> >> 7.0.0\scripts?
> >> I am learning GRASS 7.0.0 on Windows 7 by converting some GRASS 6.4
> shell
> >> scripts to GRASS 7 Python scripts (import grass.script as grass) and
> GRASS
> >> 7 PyGRASS scripts (from grass.pygrass.modules import Module).
> >> My installation is working fine. I can manually run the commands (from a
> >> shell script) in the "Command console" window of the "Layer Manager".
> For
> >> example, I can enter "g.region swwake_30m -p" in the "Command prompt"
> area
> >> and get the following results:
> >> Sun Mar 01 12:32:30
> >> 2015)
> >> g.region swwake_30m
> >> -p
> >> projection: 99 (Lambert Conformal Conic)
> >> zone: 0
> >> datum: nad83
> >> ellipsoid: a=6378137 es=0.006694380022900787
> >> north: 228500
> >> south: 215000
> >> west: 630000
> >> east: 645000
> >> nsres: 30
> >> ewres: 30
> >> rows: 450
> >> cols: 500
> >> cells: 225000
> >> (Sun Mar 01 12:32:31 2015) Command finished (0
> >> sec)
> >> I am using the "Pythonwin" IDE to develop the scripts (C:\Program Files
> >> (x86)\GRASS GIS
> 7.0.0\Python27\lib\site-packages\pythonwin\Pythonwin.exe).
> >> In the "GRASS GIS 7.0.0 GUI" Command Prompt window I type "pythonwin"
> and
> >> the IDE starts up.
> >> I have spent several days trying to understand how to create GRASS
> Python
> >> scripts and GRASS PyGRASS scripts from the online documentation(
> >> http://grasswiki.osgeo.org/wiki/GRASS_and_Python) and by studying the
> >> script samples (C:\Program Files (x86)\GRASS GIS 7.0.0\scripts). I have
> >> not
> >> been successful in getting example code to run but I am still working
> >> through the documentation.
> >> But, I should be able to run scripts located in C:\Program Files
> >> (x86)\GRASS GIS 7.0.0\scripts.
> >> Correct?
> >> 1. If I open .\scripts\d.what.rast.py in the Pythonwin IDE and try to
> run
> >> it, I get this output:
> >> OSError error(9): The handle is invalid
> >> Traceback (most recent call last):
> >> File "C:\Program Files (x86)\GRASS GIS
> 7.0.0\Python27\lib\site-packages\pythonwin\pywin\framework\scriptutils.py",
> >> line 325, in RunScript
> >> exec codeObject in __main__.__dict__
> >> File
> "C:\Users\Rob\Documents\grassscripts\pygrass\make_raster_using_mapcalc.py",
> >> line 8, in <module>
> >> g.message("Filter elevation map by a threshold...")
> >> 7.0.0\etc\python\grass\pygrass\modules\shortcuts.py", line 46, in
> >> __getattr__
> >> return self.cls('%s.%s' % (self.prefix, name.replace('_', '.')))
> >> 7.0.0\etc\python\grass\pygrass\modules\interface\module.py", line 498,
> in
> >> __init__
> >> raise GrassError(str_err % self.name)
> >> GrassError: Error running: `g.message --interface-description`.
> >> File "C:\Program Files (x86)\GRASS GIS 7.0.0\scripts\d.what.rast.py",
> >> line 45, in <module>
> >> main()
> >> line 30, in main
> >> options, flags = gcore.parser()
> >> 7.0.0\etc\python\grass\script\core.py", line 680, in parser
> >> p = subprocess.Popen([prog, '-n'] + argv, stdout=subprocess.PIPE)
> >> 7.0.0\Python27\lib\subprocess.py",
> >> line 703, in __init__
> >> errread, errwrite) = self._get_handles(stdin, stdout, stderr)
> >> line 839, in _get_handles
> >> p2cread = self._make_inheritable(p2cread)
> >> line 878, in _make_inheritable
> >> _subprocess.DUPLICATE_SAME_ACCESS)
> >> WindowsError: [Error 6] The handle is invalid
> >> main()
> >> line 30, in main
> >> 2. If I go to the "Python shell" tab on the "Layer Manager" and do File
> >> Launch Script and browse to .\scripts\d.what.rast.py, I get this
> output:
> >> sec)
> >> Launching script 'C:\Program Files (x86)\GRASS GIS 7.0.0\scripts\
> >> d.what.rast.py'...
> >> 7.0.0\gui\wxpython\gui_core\forms.py", line 718, in OnRun
> >> gcmd.Command(cmd)
> >> 7.0.0\gui\wxpython\core\gcmd.py", line 397, in __init__
> >> _("Error: ") + self.__GetError()))
> >> core.gcmd
> >> GException
> >> Execution failed: 'd.what.rast map=elevation'
> >> Details:
> >> Error:
> >> Any ideas on what might be going on here?
> >> Rob Parsons
> >> Raleigh NC
> >> -------------- next part --------------
> >> An HTML attachment was scrubbed...
> >> URL: <
> http://lists.osgeo.org/pipermail/grass-user/attachments/20150301/b41b2959/attachment-0001.html
> >> Message: 2
> >> Date: Sun, 1 Mar 2015 20:12:57 -0500
> >> From: Vaclav Petras <wenzeslaus at gmail.com>
> >> Subject: Re: [GRASS-user] GRASS 7.0 Running Scripts (.\GRASS GIS
> >> 7.0.0\scripts)
> >> Message-ID:
> >> <CABo5uVt7hq0QnHYqzV5O949h3URGxFOAjHNLxiMx=
> >> V5rSK_wRw at mail.gmail.com>
> >> On Sun, Mar 1, 2015 at 7:37 PM, Rob Parsons <jrobparsons at gmail.com>
> >> wrote:
> >> > Hello,
> >> > 7.0.0\scripts?
> >> shell
> >> GRASS
> (from a
> >> For
> >> area
> >> > Sun Mar 01 12:32:30
> >> > 2015)
> >> > g.region swwake_30m
> >> > -p
> >> > zone: 0
> >> > datum: nad83
> >> > north: 228500
> >> > south: 215000
> >> > west: 630000
> >> > east: 645000
> >> > nsres: 30
> >> > ewres: 30
> >> > rows: 450
> >> > cols: 500
> >> > cells: 225000
> >> > sec)
> Files
> >> > (x86)\GRASS GIS
> >> and
> >> > the IDE starts up.
> >> Python
> have
> >> not
> >> > Please try the example from:
> >> I linked this page from documentation as well as the other Python wiki
> >> page
> >> from the GRASS and Python page:
> >> http://grasswiki.osgeo.org/wiki/GRASS_Python_Scripting_Library
> >> Note that GRASS scripts by default cannot run from outside GRASS GIS
> >> session (environment). This is probably not emphasized enough in the
> >> documentation.
> >> > Correct?
> >> > Correct but can you please try some other module than a d.* module,
> e.g.
> >> r.out.xyz? d.* commands are somehow special (although in this case it
> >> probably doesn't matter).
> >> run
> >> > File
> >> > line 8, in <module>
> >> > __getattr__
> >> in
> >> > __init__
> >> > main()
> >> > line 30, in main
> >> > 7.0.0\Python27\lib\subprocess.py", line 703, in __init__
> >> > 7.0.0\Python27\lib\subprocess.py", line 839, in _get_handles
> >> > 7.0.0\Python27\lib\subprocess.py", line 878, in _make_inheritable
> >> > main()
> >> > line 30, in main
> >> This might be somehow related to bug in Python itself:
> >> http://bugs.python.org/issue3905
> >> However, please focus on running the scripts for GRASS GIS from GRASS
> >> session. The easiest way how to do that on MS Windows is to write the
> >> script and then to start it from GUI (File > Run script) or from Python
> >> shell tab in the GUI.
> >> It is possible to run scripts which are using GRASS modules from outside
> >> of
> >> GRASS session but it requires you to set up the GRASS environment
> >> yourself.
> >> This is possible but it has some challenges. On the other hand, if you
> >> write your script in the way that it runs (only) in a GRASS session you
> >> can
> >> use GRASS features for automatic building of interface and thus create a
> >> true GRASS module.
> File
> >> output:
> >> > sec)
> >> > d.what.rast.py'...
> >> > gcmd.Command(cmd)
> >> > core.gcmd
> >> > GException
> >> > Details:
> >> > Error:
> >> > The error message seems to be incomplete but in any case, please try
> >> with
> >> r.out.xyz script and the example script from:
> >> Vaclav
> >> > Rob Parsons
> >> > Raleigh NC
> >> > _______________________________________________
> >> URL: <
> http://lists.osgeo.org/pipermail/grass-user/attachments/20150301/6ff05a0b/attachment.html
> >> End of grass-user Digest, Vol 107, Issue 2
> URL: <
> http://lists.osgeo.org/pipermail/grass-user/attachments/20150305/74ca5f99/attachment.html
> End of grass-user Digest, Vol 107, Issue 9
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150305/1bec271e/attachment-0001.html>
