[GRASS-user] Using GRASS 6 without starting it (Python)
Pedro Camargo
veigacamargo at gmail.com
Fri Mar 6 22:31:36 PST 2015
Hi Sittichai,
The location of the database is J:\MY_PROJECT\GRASS
Is that what you wanted to know?
Thanks,
Pedro
On Fri, Mar 6, 2015 at 5:51 PM, sittichai choosumrong <
sittichai.ocu at gmail.com> wrote:
> He Pedro
> Please try to specific your GISDBASE location as the code showing below;
> import os
> import sys
> gisbase = os.environ['GISBASE'] = "C:/Program Files/QGIS
> Valmiera/apps/grass/grass-6.4.3"
> sys.path.append(os.path.join(os.environ['GISBASE'], "etc", "python"))
> gisdbase = os.path.join(os.getenv('APPDATA', 'GRASS6/grassrc6'))
> location = "AZ"
> gisdbase = "C:/Users/pcamargo/AppData/Roaming/GRASS6/grassrc6"
> mapset = "AZMAP"
> import grass.script as grass
> import grass.script.setup as gsetup
> gsetup.init(gisbase, gisdbase, location, mapset)
> Best,
> Sittichai
> On Fri, Mar 6, 2015 at 11:16 PM, Pedro Camargo <veigacamargo at gmail.com>
> wrote:
>> Hi,
>> I have been trying to use GRASS without opening it explicitly
>> following the instructions from here:
>> http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly#Python:_GRASS_GIS_6
>> Since I am on Windows, I had to adapt it a bit (and I tried many,
>> many variations). The most likely
>> import os
>> import sys
>> location = "AZ"
>> mapset = "AZMAP"
>> What I get when I run these lines is the line below:
>> 'c:\\users\\pcamargo\\appdata\\local\\temp\\tmp7wvogg'
>> The content of this file is
>> GISDBASE: C:/Users/pcamargo/AppData/Roaming/GRASS6/grassrc6
>> LOCATION_NAME: AZ
>> MAPSET: AZMAP
>> While it should be getting the contents from the file at
>> C:\Users\pcamargo\AppData\Roaming\GRASS6\grassrc6
>> What am I doing wrong?
>> Thanks,
>> Pedro
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Dr.Sittichai Choosumrong
> Lecturer,
> Geography and Geographic Information Science (GISci)
> Department of Natural Resources and Environment,
> Faculty of Agriculture, Natural Resources and Environment,
> Naresuan University, Thailand 65000
> Office: +66 55 962753
> Mobile: +66 95-635-8102
> email: sittichaic at nu.ac.th
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150306/231835ac/attachment.html>
