[GRASS-user] grass-user Digest, Vol 107, Issue 9
Anna Petrášová
kratochanna at gmail.com
Sat Mar 7 12:37:04 PST 2015
On Sat, Mar 7, 2015 at 2:14 PM, Rob Parsons <jrobparsons at gmail.com> wrote:
> Thanks for the help.
> I do not have a use case. I am learning GRASS 7.0, on Windows 7 platform,
> by going through all the online documentation, Python script examples, and
> PyGRASS examples. I will eventually get into the source code.
> I hope it is OK to use this forum for learning help?
> Sure, that's perfectly fine.
Anna
> Rob Parsons
> Raleigh NC
> On Fri, Mar 6, 2015 at 9:46 PM, Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> On Fri, Mar 6, 2015 at 8:45 PM, Rob Parsons <jrobparsons at gmail.com>
>> wrote:
>>> I converted the interactive script at the top of this page,
>>> http://grass.osgeo.org/grass70/manuals/libpython/script.html
>>> to a batch script.
>>> I understand what the script is trying to do. When I File -> "Launch
>>> script" from the "Layer Manager" GUI, the script appears to run to
>>> completion, but, this message is displayed on the "Command console":
>>> "ERROR: Unable to create file
>>> <C:\grassdata/North_Carolina/user1/.tmp/unknown/4808.1>"
>>> I have traced it to this statement in the script:
>>> map2d_2.read("map2d_1")
>>> The file was indeed created.
>>> C:\grassdata\North_Carolina\user1\.tmp\unknown>dir
>>> Volume in drive C is OS
>>> Volume Serial Number is C4D0-A091
>>> Directory of C:\grassdata\North_Carolina\user1\.tmp\unknown
>>> 2015-03-06 08:25 PM <DIR> .
>>> 2015-03-06 08:25 PM <DIR> ..
>>> 2015-03-06 08:25 PM 192 4808.0
>>> 2015-03-06 08:25 PM 192 4808.1
>>> 2015-03-06 08:25 PM 576 4808.2
>>> 3 File(s) 960 bytes
>>> 2 Dir(s) 22,857,420,800 bytes free
>>> The script prints out the 2D and 3D arrays.
>>> The 2D rasters (map2d_1 and map2d_2) are written to the 'user1' mapset
>>> but not the 3D rasters (map3d_1 and map3d_2).
>>> Has anyone successfully run this example?
>> It seems it got broken very recently, I created a ticket for that (
>> http://trac.osgeo.org/grass/ticket/2616). Do you need to use this
>> library? There is also newer library PyGRASS (
>> http://grass.osgeo.org/grass70/manuals/libpython/pygrass_raster.html),
>> it has more capabilities, so you might want to use that anyway. Perhaps if
>> you would share what is your usecase, people may have some advice.
>> Anna
>>> Rob Parsons
>>> Raleigh NC
>>> On Thu, Mar 5, 2015 at 10:42 PM, Rob Parsons <jrobparsons at gmail.com>
>>> wrote:
>>>> Yes.
>>>> I do get the "add the script path to GRASS_ADDON_PATH" prompt. After I
>>>> say 'yes' to the prompt, the script runs successfully.
>>>> Thanks!
>>>> On Thu, Mar 5, 2015 at 1:14 PM, <grass-user-request at lists.osgeo.org>
>>>> wrote:
>>>>> Send grass-user mailing list submissions to
>>>>> grass-user at lists.osgeo.org
>>>>> To subscribe or unsubscribe via the World Wide Web, visit
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-user
>>>>> or, via email, send a message with subject or body 'help' to
>>>>> You can reach the person managing the list at
>>>>> grass-user-owner at lists.osgeo.org
>>>>> When replying, please edit your Subject line so it is more specific
>>>>> than "Re: Contents of grass-user digest..."
>>>>> Today's Topics:
>>>>> 1. Re: grass-user Digest, Vol 107, Issue 2 (Anna Petr??ov?)
>>>>> Message: 1
>>>>> Date: Thu, 5 Mar 2015 13:14:05 -0500
>>>>> From: Anna Petr??ov? <kratochanna at gmail.com>
>>>>> To: Rob Parsons <jrobparsons at gmail.com>
>>>>> Cc: GRASS user list <grass-user at lists.osgeo.org>
>>>>> Subject: Re: [GRASS-user] grass-user Digest, Vol 107, Issue 2
>>>>> Message-ID:
>>>>> <CAE0EDEro0wnTAaLkgmwsvpZcUckXvXmzBUMcOv4J5qwW=
>>>>> qRZPg at mail.gmail.com>
>>>>> Content-Type: text/plain; charset="utf-8"
>>>>> On Wed, Mar 4, 2015 at 10:09 PM, Rob Parsons <jrobparsons at gmail.com>
>>>>> wrote:
>>>>> > Thanks for the direction!
>>>>> > I have successfully worked through the examples on
>>>>> > http://grass.osgeo.org/grass70/manuals/libpython/script_intro.html
>>>>> except
>>>>> > for the last one about adding a module interface to a script. I
>>>>> copied the
>>>>> > code into a python file named module_interface.py. After I File->
>>>>> "Launch
>>>>> > script" and select module_interface.py, the module GUI pops up and
>>>>> prompts
>>>>> > for the raster inputs and output. But, after clicking on "Run", the
>>>>> script
>>>>> > reports the following message:
>>>>> Before the module dialog opens, you should get a dialog asking to add
>>>>> the
>>>>> script path to GRASS_ADDON_PATH. If you do it, you should be able to
>>>>> run
>>>>> the script. Did you get this dialog?
>>>>> Anna
>>>>> (Wed Mar 04 21:55:29
>>>>> > 2015)
>>>>> > module_interface araster=el_D782_6m at PERMANENT
>>>>> braster=el_D783_6m at PERMANENT
>>>>> > output=el_r_6m
>>>>> > 'module_interface' is not recognized as an internal or
>>>>> > external command,
>>>>> > operable program or batch file.
>>>>> > (Wed Mar 04 21:55:29 2015) Command finished (0
>>>>> > sec)
>>>>> > Anyone seen this message?
>>>>> > Rob Parsons
>>>>> > Raleigh NC
>>>>> > On Sun, Mar 1, 2015 at 8:13 PM, <grass-user-request at lists.osgeo.org>
>>>>> >> Today's Topics:
>>>>> >> 1. GRASS 7.0 Running Scripts (.\GRASS GIS 7.0.0\scripts)
>>>>> >> (Rob Parsons)
>>>>> >> 2. Re: GRASS 7.0 Running Scripts (.\GRASS GIS
>>>>> 7.0.0\scripts)
>>>>> >> (Vaclav Petras)
>>>>> >> Message: 1
>>>>> >> Date: Sun, 1 Mar 2015 19:37:59 -0500
>>>>> >> From: Rob Parsons <jrobparsons at gmail.com>
>>>>> >> To: grass-user at lists.osgeo.org
>>>>> >> Subject: [GRASS-user] GRASS 7.0 Running Scripts (.\GRASS GIS
>>>>> >> 7.0.0\scripts)
>>>>> >> Message-ID:
>>>>> >> CAFvPsPBH1xVpEgff15hxknY0qeeMUeehP9bucV4FB9ZgQ_2+cg at mail.gmail.com>
>>>>> >> Hello,
>>>>> >> How do I run scripts located in C:\Program Files (x86)\GRASS GIS
>>>>> >> 7.0.0\scripts?
>>>>> >> I am learning GRASS 7.0.0 on Windows 7 by converting some GRASS 6.4
>>>>> shell
>>>>> >> scripts to GRASS 7 Python scripts (import grass.script as grass)
>>>>> and GRASS
>>>>> >> 7 PyGRASS scripts (from grass.pygrass.modules import Module).
>>>>> >> My installation is working fine. I can manually run the commands
>>>>> (from a
>>>>> >> shell script) in the "Command console" window of the "Layer
>>>>> Manager". For
>>>>> >> example, I can enter "g.region swwake_30m -p" in the "Command
>>>>> prompt" area
>>>>> >> and get the following results:
>>>>> >> Sun Mar 01 12:32:30
>>>>> >> 2015)
>>>>> >> g.region swwake_30m
>>>>> >> -p
>>>>> >> projection: 99 (Lambert Conformal Conic)
>>>>> >> zone: 0
>>>>> >> datum: nad83
>>>>> >> ellipsoid: a=6378137 es=0.006694380022900787
>>>>> >> north: 228500
>>>>> >> south: 215000
>>>>> >> west: 630000
>>>>> >> east: 645000
>>>>> >> nsres: 30
>>>>> >> ewres: 30
>>>>> >> rows: 450
>>>>> >> cols: 500
>>>>> >> cells: 225000
>>>>> >> (Sun Mar 01 12:32:31 2015) Command finished (0
>>>>> >> sec)
>>>>> >> I am using the "Pythonwin" IDE to develop the scripts (C:\Program
>>>>> Files
>>>>> >> (x86)\GRASS GIS
>>>>> 7.0.0\Python27\lib\site-packages\pythonwin\Pythonwin.exe).
>>>>> >> In the "GRASS GIS 7.0.0 GUI" Command Prompt window I type
>>>>> "pythonwin" and
>>>>> >> the IDE starts up.
>>>>> >> I have spent several days trying to understand how to create GRASS
>>>>> Python
>>>>> >> scripts and GRASS PyGRASS scripts from the online documentation(
>>>>> >> http://grasswiki.osgeo.org/wiki/GRASS_and_Python) and by studying
>>>>> the
>>>>> >> script samples (C:\Program Files (x86)\GRASS GIS 7.0.0\scripts). I
>>>>> have
>>>>> >> not
>>>>> >> been successful in getting example code to run but I am still
>>>>> working
>>>>> >> through the documentation.
>>>>> >> But, I should be able to run scripts located in C:\Program Files
>>>>> >> (x86)\GRASS GIS 7.0.0\scripts.
>>>>> >> Correct?
>>>>> >> 1. If I open .\scripts\d.what.rast.py in the Pythonwin IDE and try
>>>>> to run
>>>>> >> it, I get this output:
>>>>> >> OSError error(9): The handle is invalid
>>>>> >> Traceback (most recent call last):
>>>>> >> File "C:\Program Files (x86)\GRASS GIS
>>>>> 7.0.0\Python27\lib\site-packages\pythonwin\pywin\framework\scriptutils.py",
>>>>> >> line 325, in RunScript
>>>>> >> exec codeObject in __main__.__dict__
>>>>> >> File
>>>>> "C:\Users\Rob\Documents\grassscripts\pygrass\make_raster_using_mapcalc.py",
>>>>> >> line 8, in <module>
>>>>> >> g.message("Filter elevation map by a threshold...")
>>>>> >> 7.0.0\etc\python\grass\pygrass\modules\shortcuts.py", line 46, in
>>>>> >> __getattr__
>>>>> >> return self.cls('%s.%s' % (self.prefix, name.replace('_', '.')))
>>>>> >> 7.0.0\etc\python\grass\pygrass\modules\interface\module.py", line
>>>>> 498, in
>>>>> >> __init__
>>>>> >> raise GrassError(str_err % self.name)
>>>>> >> GrassError: Error running: `g.message --interface-description`.
>>>>> >> File "C:\Program Files (x86)\GRASS GIS 7.0.0\scripts\
>>>>> d.what.rast.py",
>>>>> >> line 45, in <module>
>>>>> >> main()
>>>>> d.what.rast.py",
>>>>> >> line 30, in main
>>>>> >> options, flags = gcore.parser()
>>>>> >> 7.0.0\etc\python\grass\script\core.py", line 680, in parser
>>>>> >> p = subprocess.Popen([prog, '-n'] + argv,
>>>>> stdout=subprocess.PIPE)
>>>>> >> 7.0.0\Python27\lib\subprocess.py",
>>>>> >> line 703, in __init__
>>>>> >> errread, errwrite) = self._get_handles(stdin, stdout, stderr)
>>>>> >> line 839, in _get_handles
>>>>> >> p2cread = self._make_inheritable(p2cread)
>>>>> >> line 878, in _make_inheritable
>>>>> >> _subprocess.DUPLICATE_SAME_ACCESS)
>>>>> >> WindowsError: [Error 6] The handle is invalid
>>>>> d.what.rast.py",
>>>>> >> main()
>>>>> d.what.rast.py",
>>>>> >> line 30, in main
>>>>> >> 2. If I go to the "Python shell" tab on the "Layer Manager" and do
>>>>> File ->
>>>>> >> Launch Script and browse to .\scripts\d.what.rast.py, I get this
>>>>> output:
>>>>> >> sec)
>>>>> >> Launching script 'C:\Program Files (x86)\GRASS GIS 7.0.0\scripts\
>>>>> >> d.what.rast.py'...
>>>>> >> 7.0.0\gui\wxpython\gui_core\forms.py", line 718, in OnRun
>>>>> >> gcmd.Command(cmd)
>>>>> >> 7.0.0\gui\wxpython\core\gcmd.py", line 397, in __init__
>>>>> >> _("Error: ") + self.__GetError()))
>>>>> >> core.gcmd
>>>>> >> GException
>>>>> >> Execution failed: 'd.what.rast map=elevation'
>>>>> >> Details:
>>>>> >> Error:
>>>>> >> Any ideas on what might be going on here?
>>>>> >> Rob Parsons
>>>>> >> Raleigh NC
>>>>> >> -------------- next part --------------
>>>>> >> An HTML attachment was scrubbed...
>>>>> >> URL: <
>>>>> http://lists.osgeo.org/pipermail/grass-user/attachments/20150301/b41b2959/attachment-0001.html
>>>>> >> Message: 2
>>>>> >> Date: Sun, 1 Mar 2015 20:12:57 -0500
>>>>> >> From: Vaclav Petras <wenzeslaus at gmail.com>
>>>>> >> Subject: Re: [GRASS-user] GRASS 7.0 Running Scripts (.\GRASS GIS
>>>>> >> 7.0.0\scripts)
>>>>> >> Message-ID:
>>>>> >> <CABo5uVt7hq0QnHYqzV5O949h3URGxFOAjHNLxiMx=
>>>>> >> V5rSK_wRw at mail.gmail.com>
>>>>> >> On Sun, Mar 1, 2015 at 7:37 PM, Rob Parsons <jrobparsons at gmail.com>
>>>>> >> wrote:
>>>>> >> > Hello,
>>>>> >> > 7.0.0\scripts?
>>>>> 6.4
>>>>> >> shell
>>>>> and
>>>>> >> GRASS
>>>>> (from a
>>>>> Manager".
>>>>> >> For
>>>>> prompt"
>>>>> >> area
>>>>> >> > Sun Mar 01 12:32:30
>>>>> >> > 2015)
>>>>> >> > g.region swwake_30m
>>>>> >> > -p
>>>>> >> > zone: 0
>>>>> >> > datum: nad83
>>>>> >> > north: 228500
>>>>> >> > south: 215000
>>>>> >> > west: 630000
>>>>> >> > east: 645000
>>>>> >> > nsres: 30
>>>>> >> > ewres: 30
>>>>> >> > rows: 450
>>>>> >> > cols: 500
>>>>> >> > cells: 225000
>>>>> >> > sec)
>>>>> Files
>>>>> >> > (x86)\GRASS GIS
>>>>> "pythonwin"
>>>>> >> and
>>>>> >> > the IDE starts up.
>>>>> >> Python
>>>>> studying the
>>>>> I have
>>>>> >> not
>>>>> working
>>>>> >> > Please try the example from:
>>>>> >> I linked this page from documentation as well as the other Python
>>>>> wiki
>>>>> >> page
>>>>> >> from the GRASS and Python page:
>>>>> >> http://grasswiki.osgeo.org/wiki/GRASS_Python_Scripting_Library
>>>>> >> Note that GRASS scripts by default cannot run from outside GRASS GIS
>>>>> >> session (environment). This is probably not emphasized enough in the
>>>>> >> documentation.
>>>>> >> > Correct?
>>>>> >> > Correct but can you please try some other module than a d.*
>>>>> module, e.g.
>>>>> >> r.out.xyz? d.* commands are somehow special (although in this case
>>>>> it
>>>>> >> probably doesn't matter).
>>>>> try to
>>>>> >> run
>>>>> >> > File
>>>>> >> > line 8, in <module>
>>>>> >> > __getattr__
>>>>> 498,
>>>>> >> in
>>>>> >> > __init__
>>>>> d.what.rast.py",
>>>>> >> > main()
>>>>> d.what.rast.py",
>>>>> >> > line 30, in main
>>>>> >> > 7.0.0\Python27\lib\subprocess.py", line 703, in __init__
>>>>> >> > 7.0.0\Python27\lib\subprocess.py", line 839, in _get_handles
>>>>> >> > 7.0.0\Python27\lib\subprocess.py", line 878, in _make_inheritable
>>>>> d.what.rast.py",
>>>>> >> > main()
>>>>> d.what.rast.py",
>>>>> >> > line 30, in main
>>>>> >> This might be somehow related to bug in Python itself:
>>>>> >> http://bugs.python.org/issue3905
>>>>> >> However, please focus on running the scripts for GRASS GIS from
>>>>> GRASS
>>>>> >> session. The easiest way how to do that on MS Windows is to write
>>>>> the
>>>>> >> script and then to start it from GUI (File > Run script) or from
>>>>> Python
>>>>> >> shell tab in the GUI.
>>>>> >> It is possible to run scripts which are using GRASS modules from
>>>>> outside
>>>>> >> of
>>>>> >> GRASS session but it requires you to set up the GRASS environment
>>>>> >> yourself.
>>>>> >> This is possible but it has some challenges. On the other hand, if
>>>>> you
>>>>> >> write your script in the way that it runs (only) in a GRASS session
>>>>> you
>>>>> >> can
>>>>> >> use GRASS features for automatic building of interface and thus
>>>>> create a
>>>>> >> true GRASS module.
>>>>> do File
>>>>> >> output:
>>>>> >> > sec)
>>>>> >> > d.what.rast.py'...
>>>>> >> > gcmd.Command(cmd)
>>>>> >> > core.gcmd
>>>>> >> > GException
>>>>> >> > Details:
>>>>> >> > Error:
>>>>> >> > The error message seems to be incomplete but in any case, please
>>>>> try
>>>>> >> with
>>>>> >> r.out.xyz script and the example script from:
>>>>> >> Vaclav
>>>>> >> > Rob Parsons
>>>>> >> > Raleigh NC
>>>>> >> > _______________________________________________
>>>>> >> URL: <
>>>>> http://lists.osgeo.org/pipermail/grass-user/attachments/20150301/6ff05a0b/attachment.html
>>>>> >> End of grass-user Digest, Vol 107, Issue 2
>>>>> URL: <
>>>>> http://lists.osgeo.org/pipermail/grass-user/attachments/20150305/74ca5f99/attachment.html
>>>>> End of grass-user Digest, Vol 107, Issue 9
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150307/01b6328d/attachment-0001.html>
