[GRASS-user] GRASS jumps to shell immediately after start
    Michal Zimmermann
    zimmicz at gmail.com
    Mon Mar  9 06:32:04 PDT 2015
when run with the command you sent, it gives the following output:
Cleaning up temporary files ...
Starting GRASS ...
/usr/lib/grass64/etc/Init.sh: 409: /usr/lib/grass64/etc/Init.sh:
/etc/clean_temp: not found
/usr/lib/grass64/etc/Init.sh: 580: /usr/lib/grass64/etc/Init.sh:
/etc/set_data: not found
I installed 6.4 from the official ubuntu repo and 7.0 comes from ubuntugis
repo. init.sh is completely missing for v7.0.
On Mon, Mar 9, 2015 at 2:29 PM, Micha Silver <micha at arava.co.il> wrote:
>  Hi Michal
> (keeping this on the list...)
> On 03/09/2015 02:46 PM, Michal Zimmermann wrote:
> That works. I always thught you could run grass from interactive shell,
> was I wrong?
> You can definitely run GRASS from the shell, in text mode only. It's been
> like that for a few years now - since about 1983  ;-)
> How did you install? Maybe try running the Init.sh
> (/usr/lib/grass64/etc/Init.sh) to follow error messages.
> Also what shell are you running? I seem to recall seeing in the original
> post zsh? Wonder if that could be the problem?
>  On Sun, Mar 8, 2015 at 10:21 PM, Micha Silver <micha at arava.co.il> wrote:
>>  Weird
>> Well, starting GRASS in text mode is really nothing more than setting
>> some environment variables. I'd suggest you try to setup the environment
>> manually, then try to run some modules.
>> Here's the explanation how to do this:
>> http://grasswiki.osgeo.org/wiki/Working_with_GRASS_without_starting_it_explicitly#Bash_examples_.28GNU.2FLinux.29
>> On 03/08/2015 11:03 PM, Michal Zimmermann wrote:
>>   I did, it always throws me out.
>> Od:Micha Silver <micha at arava.co.il>
>> Odesláno:8. 3. 2015 22:02
>> Komu:Michal Zimmermann <zimmicz at gmail.com>; GRASS user list
>> <grass-user at lists.osgeo.org>
>> Předmět:Re: [GRASS-user] GRASS jumps to shell immediately after start
>>  Try to delete the file ".gislock" in the MAPSET directory that you are
>> trying to work with, then start grass64.
>> On 03/08/2015 09:15 PM, Michal Zimmermann wrote:
>> No I can't. But it seems grass is running, because when i try to run it
>> again in the same location, it says concurrent use is not allowed
>> On Sun, Mar 8, 2015 at 8:11 PM, Micha Silver <micha at arava.co.il> wrote:
>>>  I guess you mean that the GRASS environment is not being setup? Can you
>>> run i.e. g.version ?
>>> On 03/08/2015 08:05 PM, Michal Zimmermann wrote:
>>>  Hi, when I try to run grass (both 6.4 and 7.0) with -text interface,
>>> it immediately switches back to shell. I haven't found anything related to
>>> this issue, can anyone help me? Thanks
>>> Michal Zimmermann (zimmi)
>>> WWW: http://www.zimmi.cz
>>>  This mail was received via Mail-SeCure System.
>>> grass-user mailing listgrass-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150309/15d31fe6/attachment.html>
