[GRASS-user] issues with addon scripts
Bulent Arikan bulent.arikan at gmail.com
Sun Mar 15 13:43:09 PDT 2015
Dear List,
I am having issues with adding on scripts to GRASS 7.0 stable (running Mac OS 10.10.2 Yosemite). I am the Administrator. I have the “Modules” folder that contains bin, scripts, etc. in /Users/bulentarikan/Library/GRASS/7.0
The add-on base is defined as: bash: /Users/bulentarikan/Library/GRASS/7.0/Modules: is a directory
The path is:
bash: /Applications/GRASS_7.0/GRASS-7.0.app/Contents/MacOS/bin:/Applications/GRASS_7.0/GRASS-7.0.app/Contents/MacOS/scripts:/Users/bulentarikan/Library/GRASS/7.0/Modules/bin:/Users/bulentarikan/Library/GRASS/7.0/Modules/scripts:-framework:
The script I am trying to add on is not available in the add-on repository as far as I know. I used BatChmod to make sure that I have the permissions of the (.py) script folder. Then I moved the script into the “scripts” folder located under (right click on the GRASS 7.0 app >Contents>MacOS). In the scripts folder, all scripts have black icons with the word ‘exec’ on the upper left corner. The script I dropped into the scripts folder did not have that, so I used:
chmod +x /Users/bulentarikan/Desktop/r.landscape.evol7.py
However, that did not change anything! The file is still not executable. So, my first question is, how can I make the script file an executable file?
In the Terminal, I call the script by typing its name. I get the error below:
Does this mean that I also need to have the executable file in /Users/bulentarikan/Library/GRASS/7.0/Modules?
Thank you!
BÜLENT ARIKAN
Assistant Professor
Department of Ecology and Evolution
Assistant Director
Eurasia Institute of Earth Sciences
Istanbul Technical University
Maslak-Sarıyer
Istanbul
34469
Turkey
http://web.itu.edu.tr/~bulentarikan/index.html <http://web.itu.edu.tr/~bulentarikan/index.html>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150315/89c0964c/attachment-0001.html>
Name: Screen Shot 2015-03-15 at 10.02.52 PM.png
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150315/89c0964c/attachment-0001.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150315/89c0964c/attachment-0001.jpg>
