[GRASS-user] Projection errors
Nikos Alexandris nik at nikosalexandris.net
Thu Mar 26 09:03:41 PDT 2015
Paul, I hope I understand what you are asking. So, this is what works
for me:
1) import the Landsat(8 or any) imagery in a Location defined by their
"native" spatial reference system. In GRASS7, you can do something
quickly from the command line:
# create location
grass7 -c /path/to/georeferenced.image
/path/to/grass-data-base/NameForNewLocation
# import
r.in.gdal ...
# set your region, for example
g.region raster=Imported_Band_1
# create a vector out of the current region
v.in.region out=Working_Region
2) create another location based on the espg in question and reproject
in it the stuff from the "source" Location. Again, quickly from the
command line:
# create location based on given epsg
grass7 -c epsg:27700 /path/to/grass-data-base/NameForEPSG27700Location
# reproject the "region" vector map...
v.proj in=Working_Region dbase=/path/to/grass-data-base
location=NameForNewLocation mapset=PERMANENT #or other Mapset!
# set region usig it
g.region vect=Working_Region
# reproject your rasters -- example below for one image
r.proj input=Imported_Band_1 dbase=/path/to/grass-data-base
In general, this is the best way (I know of) to reproject raster data
from one Location to another one (with different reference systems of
course).
Nikos
ps- please, let us not forget to keep discussion in the public mailing
list
On 26.03.2015 17:40, Paul Shapley wrote:
> Yes...that's correct
> On 26 Mar 2015 15:29, "Nikos Alexandris" <nik at nikosalexandris.net>
> wrote:
>> On 26.03.2015 14:34, Paul Shapley wrote:
>>  I'm having the problem of projecting a source map (landsat 8 image)
>> into a
>>> target location (Ordnance Survey UK) in Grass 7.
>> Is it this one: <EPSG:27700> ?
>> Nikos
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Nikos
