[GRASS-user] System locale is not usable issue.
Rodrigo A. León Loya
rleonloya at geociencias.unam.mx
Mon May 4 08:32:42 PDT 2015
El 2015-04-30 15:21, Markus Neteler escribió:
> On Wed, Apr 29, 2015 at 3:35 AM, Rodrigo A. León Loya
> <rleonloya at geociencias.unam.mx> wrote:
>> Hello,
>> I have trouble with starting grass. I messed up with my
>> .bash_profile and
>> the terminal commands and programs running under python were gone
>> (including
>> GRASS).. I fixed the other programs and but when i try to start
>> grass the
>> next error is printed in the terminal:
>> "System locale is not usable. It indicates misconfigured
>> environment.
>> Reported error message: unsupported locale setting
>> Fix system locale settings and then try again."
>> I`m using MAC OS by the way. I tried to uninstall and re-install
>> grass but
>> didn´t work. So I don´t now what to do. Thank you very much in
>> advance for
>> your help. Have a nice day.
> Can you please post the results of these two commands (to be executed
> in a terminal):
> echo $LC_ALL
> echo $LANG
> In the startup script there is test for these.
> Another thing to try: edit (or delete) the file
> $HOME/.grass7/wx
> which may contain a line "language;..." <<-- remove from file. Or
> delete this wx file which just contains some GUI user setting.
> Let us know how it goes,
> Markus
Hello Markus
The results for both lines in terminal are:
en.US.UTF-8
And i have no archive named wx, in that directory there is just
another empty carpet named "toolboxes" and another text file named "rc"
which lines are the Location name, the Gisdatabase, Mapset and the final
one GUI: wxpython.
Thank you very much and have a nice day
RODRIGO ALEJANDRO LEÓN LOYA
ESTUDIANTE DE DOCTORADO
Posgrado en Ciencias de la Tierra, UNAM Campus Juriquilla
Blvd.Juriquilla No. 3001, Querétaro, 76230, México (442) 238-1104 ext.
148
https://www.researchgate.net/profile/Rodrigo_Leon_Loya
