[GRASS-user] GRASS crashes while running i.atcorr
Jake Chila
jake.chila at gmail.com
Mon May 4 10:11:22 PDT 2015
Hi all,
So I think I have managed to fix my problems with help from Markus and
Nikos. As it turns out my issue was predictably (and embarrassingly) quite
simple. In my parameters file both the month and day variables were in
float format and so had the decimals after them which I think caused some
problems in the program.
I also found an old email in this list which said to convert the DEM to an
integer so I also did that.
Part of my project will be to compare the results from i.atcorr to those
produced by the Atmospheric Correction Module in PCI Geomatica and so if
there is interest I would be happy to post my results!
Thanks again,
JDC
On Fri, May 1, 2015 at 11:33 AM, Jake Chila <jake.chila at gmail.com> wrote:
> hi all,
> So I am trying to run i.atcorr but every time I run it, the whole program
> goes unresponsive and crashes. Has anyone experienced this before? Is there
> any way I can fix it?
> One thing that might be causing it is my parameters text file. I'm not
> totally sure I understand what all the fields are but here is an example of
> the parameter files I have created. This one is for the second band of a
> landsat 5 TM scene over central British Columbia
> 7
> 8 15 18.49 -116.027755 50.267045
> 2
> 0
> 0
> 0
> -1000
> 26
> I understand most of the parameters except the aerosol model, mean target
> elevation and sensor height. Are these in the metadata file? I don't know
> about the aerosol module, but for the elevation, doesn't this come from the
> DEM attached? Lastly, I went with -1000 for sensor height because the grass
> wiki page says -1000 sensor height (here, sensor on board a satellite) so I
> assumed this was a preset value.
> Once again, I don't know if the parameter file is the issue, or the only
> issue at least, so any advice running i.atcorr would be much appreciated!
> Thanks,
> JDC
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150504/0f489fd9/attachment.html>
