[GRASS-user] conditional buffering with DEM
Ahmet Temiz
ahmettemiz88 at gmail.com
Mon May 4 12:40:30 PDT 2015
thank you all,
Actually, I coudn't find time to test it.
perhaps creating bufferr from the line then querying these buffeds on DEM
The process is for estimating effect of Flood.
Do you suggest a way?
regards
On Friday, May 1, 2015, Nikos Alexandris <nik at nikosalexandris.net
<javascript:_e(%7B%7D,'cvml','nik at nikosalexandris.net');>> wrote:
> * Moritz Lennert <mlennert at club.worldonline.be> [2015-04-23 20:58:10
> +0200]:
> > On 23/04/15 16:44, Ahmet Temiz wrote:
> > > thank you Nikos
> > > I meant that creating buffers from a line, which also querying DEM
> values.
> > > DEM is in subquery position of buffer map
> > You cannot do that directly, AFAIK, but using r.mapcalc you can combine
> > the two variables. Different paths are possible. Here's one (supposing a
> > buffer of 500m):
> > - Create a raster map with distance to the line using r.grow.distance
> > - Use r.mapcalc in order to check for both distance and DEM value, e.g.
> > NewMap = if(DEM > 100 && DEM < 200 && distance < 500, 1, null())
> > This will give you a map with non-null (value 1) in those pixels that
> > are within the buffer distance and that correspond to the DEM-related
> > condition.
> > Is this what you are looking for ?
> > Another path would be combining r.buffer output with the DEM in
> r.mapcalc.
> > Moritz
> Dear Ahmet,
> did Moritz' suggested approach match your needs?
> Thank you, Nikos
Ahmet Temiz
Jeoloji Müh.
Afet ve Acil Durum Yönetimi Başkanlığı
Bilgi İşlem Dairesi Başkanlığı-CBS Grubu
________________________
Ahmet Temiz
Geological Eng.
Information Systems - GIS Group
Disaster and Emergency Management
of Presidency
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20150504/fa45bdd4/attachment.html>
